Tranny making tapping or nocking sounds
Old Oct 27, 2005 | 09:03 PM
'92FlareSide's Avatar
'92FlareSide
My transmission on my 92 f150 2wd has been recently making a tapping sound or a nocking sound whenever I accelerate, at any speed(highway and road)
Took it to a tranny shop, got oil changed, they said that nothing seems wrong. They said it's not worth it to go in and look for a problem, cause most likely, there will be more than one problem, and cost to much to fix it.
What could it be?
Old Oct 27, 2005 | 09:08 PM
Popa Tim's Avatar
Popa Tim
Have you checked the tranny mounts?
they tend to get loose.
Which tranny do you have?
Tim
Old Oct 27, 2005 | 09:26 PM
'92FlareSide
The shop tghtend those when i took it in,
I dont know what tranny i have, how to find out. sorry
Old Oct 27, 2005 | 09:31 PM
Popa Tim's Avatar
Popa Tim
Theres a sticker on the drivers door or doorjam. Tranny code E is E4od and U (it think) is for the ZF
Are you sure its coming from the tranny and its not Ping or engine knock?
Try running 91 octane and see if it goes away.
Old Oct 27, 2005 | 09:44 PM
'92FlareSide
well,my engine is also acting weird
I can hear a clicking sound whenever i drive it. The sounds are bouncing of things like fences or house, thats how i can hear the engine clicking sounds. Could it be the lifters or valves.
What will putting 91 octane in it do?
Old Oct 27, 2005 | 09:46 PM
quicklook2's Avatar
quicklook2
could be cracked exhaust manifold, or a loose spark plug, or a burned ignition wire.
Old Oct 27, 2005 | 10:18 PM
'92FlareSide
On the sticker on the door jam it says:trans = E
I replaced the plugs a while ago, but the other stuff i don't know
Old Oct 29, 2005 | 09:49 PM
Popa Tim's Avatar
Popa Tim
Does the ticking sound happen when you're not moving?
Also visit http://fordfuelinjection.com/?p=13 and learn to pull your engine codes for free. it will take a few times to get used to counting the blinks. The EEC-IV system Ford uses is pretty good!
91 octane resists ping better than 87. it cost more but most vehicles don't need it. Its a cheap check to see if its ping or not.
As Quicklook2 mentioned, it could be a cracked or warped exhaust manifold. Thats one of the more common repairs on the 302 & 351 engines.
Look at your running engine when its real dark. If you see even the slightest flash that would likely be a spark that didn't stay in the wires = time to replace at least that wire.
Old Oct 29, 2005 | 10:11 PM
'92FlareSide
Well the ticking sound only happens when i am accelerating.
I will try to pull the codes, but i read on how to do it and it seems complicated.
My exhaust manifold i thinks has a small hairline crack in it from a while ago, but i haven't looked at it lately
The plug wires were also replaced not to long ago, but i will go ahead and try that as well.
Old Oct 30, 2005 | 11:31 AM
Red Raider 4x4's Avatar
Red Raider 4x4
Sounds like a problem I'm still having, I'll bet its your passengerside exhaust manifold is warped and needs replaced, and your gasket is getting bad. This is no cure with a new exhaust manifold, I speak first hand with this problem. I went to Autozone and have purchased some Seal 4 good manifold gaskets that are reusable and aluminum. I'll let you know if this works, mine only ticks under acceleration, actually you can hear it then, yours is leaking at all times also, its just you can't hear it until you accelerate. If you have noises in your E40D tranny, It's probley up for a rebuild, mine went at 160,000 and cost 1,500.00 with all heavy duty high performance parts along with a stall. If you plan on keeping the truck get this fixed,if not save your cash. Oh yeah get another opinion on your tranny, I had some yum yum head tell me my computer was shot and the truck had low voltage, I laughed at him, the truck could barely get up the hill when I left his shop, it was slipping so bad and made some god awful noises. Get a second opinion most mechanics at these shops really do not have any Idea what they are talking about, they motivate me to keep on using this website for knowledge and do it yourself mechanics. Hope this helps.
Old Oct 30, 2005 | 06:58 PM
'92FlareSide
Well, you are saying that mine ticks all the time but it only ticks when I am accelerating.
I do want to keep my truck, I love it also. But, I cant stand when it is performing badly, and i dont know what the problem is.
You seem to have the same symptomes as I do, and you suspect it to be the passenger side exhaust manifold, and the gasket needing replacement. Can i just buy some new headers for it, and replace both sides?
Thanks for the info.
Old Oct 30, 2005 | 07:08 PM
Popa Tim's Avatar
Popa Tim
Code reader for this era truck is about $30 and available at your local parts store, walmart, online.... Lots of choices. I'm cheap so I learned to count.
Definite pull your codes if the trucks not running right. Keep in mind that vacuum and fuel pressure are not directly monitored, so if you have the means have them checked.
Go ahead and try the higher octane fuel, if the noise is significantly reduced then its probably ping.
Old Oct 30, 2005 | 07:14 PM
'92FlareSide
You can buy a code reader for a vehicle that is befor the year '96? Will this be able to be bought at an AutoZone.
If not, where can this be found at.
How can you check the vacuum and fuel pressure your self.
Old Oct 30, 2005 | 07:24 PM
Popa Tim's Avatar
Popa Tim
Yes autozone stocks the Actron model for $25 at my store. They may pull your codes for free if you ask them. Not all stores can pull the pre-96 ford codes for free though.
To check the vacuum, you'll need a vacuum gauge, anywhere up to $50 if its got a vacuum pump with it.
To check the fuel pressure you need a fuel pressure gauge. This is about $50 too.
Autozone may check both of these for you if its a slower day. It dont hurt to ask before you shell out $$$ in my opinion.
Old Oct 30, 2005 | 07:30 PM
'92FlareSide
Ok, i will go there tomorow and try to get the codes pulled if not then i will do something about it any way.
What are the normal range for the Fuel and Vacuum gauges supposed to be at, If you happen to know.
