Block Heater Install??
Old Oct 27, 2005 | 07:53 PM
otpracer100's Avatar
otpracer100
Hey everyone,my first upstate N.y. winter is fast approaching. My truck must be a southern truck because i can't find a block heater.Can anyone tell me what is involved in installing one? thanks. Dave
Old Oct 27, 2005 | 11:30 PM
ltfox's Avatar
ltfox
look right above the oil filter. You should find a cord attached to the heater. I don't think their are too many psd without a heater?? who knows.
Old Oct 28, 2005 | 08:22 PM
otpracer100
I will look again,but i don't think it's there.I assumed it was an option.Why would anyone from the south need one?
Old Oct 28, 2005 | 08:39 PM
stroker2's Avatar
stroker2
Look down along side of the radiator, drivers side. Should be a 3 prong 110 AC connector to plug an extension cord into. Probably still has the cap over the prongs to keep them clean. I think it was an option in '97, so it might not be there, but not too many psd don't have it.
Old Oct 28, 2005 | 09:02 PM
barebackjake's Avatar
barebackjake
it was an option in 97, as long as the glow plug system is in good shape it should start down to 0's you can get the block heater from the stealership, just gotta drain the coolant pull the plug out where that thing goes in right above the oil filter its a 1" plug and thread the block heater in, use some loctite thread sealer on the threads. fill with coolant and your good to go. just route the cord on the frame rail and put some wire loom over it and ziptie it down.
daveyo
Nov 23, 2025 12:45 PM
kenadian
Dec 21, 2007 12:37 PM
ExpyBob
Car/truck Buying Advice
19
Aug 18, 2006 05:13 PM
BowDown
Apr 25, 2006 06:28 PM
pullnit
Feb 1, 2005 02:55 AM
