460 carb problems
Old Oct 27, 2005 | 07:27 PM
johnsf's Avatar
johnsf
460 carb problems
I have a 56 F100 with a 460 tricked up engine, my problem seems to be in the Edelbrock 600cfm carb. When the truck sits for more than a day I have a rough time getting it started, it has en electric choke,it almost seems like the carb is out of fuel and I have to crank it awhile to refill the carb. The engine runs fine after it starts except on take off from a stop it does seem the bog just for a sec and then goes.I replaced the accelerator pump in the carb but it didn't seem to make much difference. Should I start to play with the MSD distributor as far as timing? Any help?
Thanks.
John
Old Oct 27, 2005 | 08:40 PM
Bear 45/70's Avatar
Bear 45/70
I would suspect the carb has a leak and is draining the float bowl.
Old Oct 30, 2005 | 08:08 PM
bluesky636's Avatar
bluesky636
You might get better results on the 385 series engine forum. This is the FE forum.
https://www.ford-trucks.com/forums/f...splay.php?f=53
F350dog
33
Oct 24, 2024 12:53 PM
RARAROY
Aug 5, 2016 01:45 PM
Hodge_justin
May 5, 2008 08:54 AM
Bobtailfan
Nov 21, 2005 05:22 PM
jeandras
Feb 17, 2002 11:27 PM
