No Heat - Cannot Find Heater Control Valve
I have a 97 E350 6.7L V10, 15 passenger model.
I have the part, so I know what it looks like, but I spent 15 minutes looking under the airbox, and around the front, cant see it. Is there a trick to finding it?
Thanks in advance for any support...
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
blows cold air. Heard alot about BLEND DOOR problems, but not on E-series. Is
there a place I should look for the problem? This is the 5.4 engine.
Thanks in advance for advice.
I looked in the 04 shop manual and cannot find a heater control valve so either they changed the design, there isn't one, or I just can't find it. All temperature contol in the 04 appears to be based on airflow and blend door positions. The temp is controlled by an electrical temperature blend door control motor under the paasenger side dash. If you want to look into the heater core area it is accessed from inside the van also under the passenger dash. From everything I've seen you should at least have heat in the back if your van is equipped with it.
crs5357,
I think your problem may be the electrical temperature blend door control motor under the paasenger side dash I mentioned above. I haven't found any troubleshooting informtaion for it.
I thought these vans were all simular but there may have been changes prior to 04 so my info may not be of any help. Good luck sorting it
