89 F250 - LD vs HD. differences?
Old Oct 28, 2005 | 07:00 PM
ghunt's Avatar
ghunt
Originally Posted by andym
Only certain years did. Not sure when it started, though.
I noticed in our local car-ad thing, there is a place that has two diesel F-250's...one is a '96 supercab cab longbed, and the other is a '97 supercab short bed. I assume that since the shortbed one has a diesel, that makes it an HD version, right?
Old Oct 28, 2005 | 09:27 PM
Argo's Avatar
Argo
I would agree with that statement, because I do not believe that the diesel was available below 8,600 GVWR.
Old Nov 3, 2005 | 01:00 AM
russell56443's Avatar
russell56443
Cool!!!!!!!
Now I dont feel so bad about what I paid for my 88 F250 xtra cab,($3000 a year and a half ago)It had a new tranny,transfer case and other goodies and I didnt even realize it was a HD?
It's one hell of a truck to say the least!
Old Nov 4, 2005 | 06:45 AM
oldsw-31's Avatar
oldsw-31
Based on the info off the Door tag you can determine if its a HD version. according to my factory service manual there was 3 different GVWR. 6600 8600 and 8800. this applies to the 4x4 version
the 8600 was used in the regular cab trucks. 8800 was used in the ext cab
you can also tell by the type-GVW code and the spring codes.
I have a factory service manual that covers the 87, 92-00 trucks. it breaks down the door sticker codes.
if you need help decoding them I may be able to help.
Old Apr 9, 2019 | 04:57 PM
woodson84's Avatar
woodson84
So my 4x4 F-250 GVWR from the sticker is 8600. It's the XLT Lariat with the 460. From what I read here this is the HD, is that right?
I've also seen that stock towing capacity is 10k lbs. Does that seem right?
Old Apr 9, 2019 | 05:12 PM
Nothing Special's Avatar
Nothing Special
Yes, an F-250 with a GVWR over 8400 lbs is an F-250HD.
Ford trucks of this vintage don't have a tow rating. They have a GCWR, which is Gross Combined Weight Rating. That's the maximum weight of the truck, trailer, and everything in both the truck and trailer. So to know how heavy a trailer you can tow you need to know the GCWR and the weight of the loaded truck while you are towing. Put more weight in the truck and the tow rating goes down.
The GCWR depends mostly on engine, trans, and axle ratio. My 1997 F-250HD owners manual gives the following GCWRs, all for a 460 (if yours isn't a '97 I don't guarantee it will be the same):
  • 12,000 lbs with manual trans and 3.55 gears
  • 15,000 lbs with automatic trans and 3.55 gears
  • 16,000 lbs with manual trans and 4.10 gears
  • 18,500 lbs with automatic and 4.10 gears
Old Apr 9, 2019 | 05:29 PM
woodson84's Avatar
woodson84
Interesting!
The GCWR depends mostly on engine, trans, and axle ratio. My 1997 F-250HD owners manual gives the following GCWRs, all for a 460 (if yours isn't a '97 I don't guarantee it will be the same):[list]
Mine is a 1990 with an automatic transmission but my sticker is mucked up and I can't read the axle code. Going to try to clean it off but I might be counting teeth. Any easier methods?
Old Apr 9, 2019 | 06:38 PM
Nothing Special
.... Mine is a 1990 with an automatic transmission but my sticker is mucked up and I can't read the axle code. Going to try to clean it off but I might be counting teeth. Any easier methods?
Put it in neutral and jack up one back tire. Turn the tire TWO full revolutions and count how many times the driveshaft turns. If the driveshaft turns about 3 1/2 turns it's a 3.55, a little over 4 times is a 4.10. (Of course it's also possible that some time in the past 29 years someone regeared it and maybe its 3.73, or 4.56, or whatever...)
If you can't spin the tire like that (one in the air, trans in neutral, no parking brake), then you might have a limited slip diff that isn't completely toasted yet. In that case jack up both back tires, turn one of them ONE full turn (the other tire should turn the same amount in the same direction if you have a limited slip) and count driveshaft revs. Again, 3 1/2 is 3.55, a little over 4 is 4.10, ...
Old Apr 11, 2019 | 05:28 AM
tjc transport's Avatar
tjc transport
i ain't rite
easiest way to tell LD and HD is by the rear axle. if it has a full floating axle, it is HD. if it has a semi floating axle, it is a LD.
stanglver1511
Dec 16, 2013 07:14 AM
nonrev321
Sep 8, 2012 01:37 PM
F250GH
Apr 28, 2011 02:53 PM
Ken Blythen
Feb 21, 2008 12:09 PM
Ty_Yota
Nov 4, 2001 11:13 PM
