Sponsored by: Real Truck
Removing bed bolts
Old Oct 26, 2005 | 02:38 PM
Gray Wolf's Avatar
Gray Wolf
Removing bed bolts
I'd like to remove the front two bed-bolts in order to then bolt down a steel plate that will have a 12 volt winch on it.
Are these bolts threaded into a tapped frame rail or captive nut so that I can replace the bolts from the top after I've slid my plate over the holes? Or did Ford put a loose nut on the bottom that I'll never get back on?
2005 F350 long box
Old Oct 26, 2005 | 02:52 PM
2002 F350V10's Avatar
2002 F350V10
they have a clip nut underneath. just take the bolt from the top out and re use. bill
