97 Explorer 5.0 A/C Question
Old Oct 26, 2005 | 11:45 AM
4.0 Beast's Avatar
4.0 Beast
Is it true that if the refrigerant is low or none that the compressor wont turn on? When i put it on max a/c and turn the fan on, i dont hear anything engaging. I was told that if there is a leak and no refrigerant is in the system, that it won't turn on. That just doesnt sound right, so I figured i'd ask..... thanks.
Old Oct 26, 2005 | 11:55 AM
gibsonj's Avatar
gibsonj
System has a low pressure cut-out to protect the compressor. When you turn your inside dash switch to A/C, you should see the clutch on the front of the compressor engage. If not, I suspect it's critically low on refrigerant and the cut-out switch has disabled the circuit to the clutch.
Old Oct 26, 2005 | 12:21 PM
4.0 Beast's Avatar
4.0 Beast
Yea, its not even remotely doing anything like that. its almost as if the system has no power. i guess it doesnt have any refrigerant. i was told that it was recharged just before i bought it and blew cold air. some time in the span of 2 weeks or so, it is now empty. there goes another couple hundred fixing a leak...... plus refrigerent.........
Old Oct 27, 2005 | 10:14 AM
gibsonj's Avatar
gibsonj
If it lost charge that quick, then its a significant leak.
Check this web post:
http://www.imcool.com/articles/airco...ccumulator.htm
Accumulators are prone to rust through and leak, so might be your point of failure.
Just to eliminate variables, if you want to make sure the compressor in fact runs, you can disconnect the connector from the cut-out switch on top of the accumulator and jumper across the two terminals in the plug. This will close the circuit to the compressor and cause it to run. Don't do this for long, though, since the compressor will damage quickly without refrigerant.
The best advice is to hook up a manifold gauge and check the pressure. If the low side pressure reading is below 50 psi, then its a pretty good indicator of low charge. But, if you have a significant leak, which sounds like you do, you really need to locate the hole and fix it.
Old Oct 27, 2005 | 10:21 AM
4.0 Beast's Avatar
4.0 Beast
Wow, i read that little article and they say the problem is in 97's with the 5.0 liter engine. Thats what I have!!! I'll check the accumulator.....i'm certain its that because my truck spent most its life in Indiana...... Thanks for the info!
Old Oct 27, 2005 | 10:22 AM
texans's Avatar
texans
have dye put in the system to find out where it is leaking at.
Old Oct 27, 2005 | 11:11 AM
4.0 Beast's Avatar
4.0 Beast
Hmm, i checked the accumulator and that doesnt seem to be the problem... i dont see a bit of rust on it. Boy, was i disappointed when that wasnt the problem. I guess I'll have to do the dye thing....
Old Oct 27, 2005 | 11:35 AM
texans's Avatar
texans
just charge the system and add the dye to it. it will leave a green flurestent color where it is leaking from. GL
Old Oct 28, 2005 | 02:39 AM
texan2004's Avatar
texan2004
You may or may not be able to see the leak depending on where it is even with the dye. This is one of those things I usually just spend the money on have the AC guy do expecially living in Houston.
The AC wenbt in my 93 F-150 in 2001
The AC went in my 96 Explorer in 2004
The AC is going bad in my daughter's 97 Ranger and it's 2005.
The AC just went in your 97 Explorer and it's 2005
Notice a pattern here? (8 years)
FYI - I've never had a single problem with the AC after paying for the fixes. It's eitehr the evaporator core or the compressor. Best to replace both since the other one that isn't bad is probably only a year or so away from failing.
Old Nov 5, 2005 | 10:28 PM
zobie18's Avatar
zobie18
i just had a new evaportator put in my 97 5.0 this past summer. drove me crazy. finally bit bullet an paid the fiddler to fix it.
