High idle on remote starter
Old Oct 26, 2005 | 11:01 AM
jello's Avatar
jello
I've hooked my high idle to my remote starter with a timer relay. My question is how long should the truck idle at normal rpm before I kick in the high idle? Right now I have it set to come on after 2.5 minutes.
Old Oct 26, 2005 | 11:34 AM
sgthawkusmc's Avatar
sgthawkusmc
To be honest with you, I think you'll find it already high idles when you remote start it. Mine stays at about 1,900 until I hit the brake when I first get in.
Old Oct 26, 2005 | 01:04 PM
jello's Avatar
jello
My truck idles under 750 when I start it. High idles at 1200. Is 2.5 minutes long enough before high idle?
Old Oct 26, 2005 | 01:06 PM
mhoefer's Avatar
mhoefer
I think if your truck is cold you will find it idles up on its own. I set mine high idle and it kicks on in a couple mintes. Well after the oil pressure has come up. That would be my only concern is oil Pressure is up before high idle. Heats up the truck way faster. My hi idle is the mod done on this site, runs at 1250.
Old Oct 26, 2005 | 01:56 PM
sgthawkusmc
Correction! I said 1,900. I meant 900 rpms!! DOH! I also have the high idle mod hooked to an upfitter switch. Personally, I'd never run it that high until it's warmer. At least a couple minutes.
