1978 - 1996 Big Bronco
Tires rub
Old Oct 26, 2005 | 02:16 AM
bgblktruk's Avatar
bgblktruk
Tires rub
Hey all I am doing some research on some fixed for my truck and was hoping you can help me out. I have an 88 with a 4" superlift and I run 33x12.5 on 15" rims. The tires rub before full turn and I've lost some turning radius. I'm wondering if there is anything I can do to fix this. I'd like to keep the rims I have even though I don't love them but I don't want to spend the money.
Thanks
mike
Old Oct 26, 2005 | 08:21 AM
Jdenninger's Avatar
Jdenninger
it sounds like the backspacing is incorrect.
Old Oct 26, 2005 | 09:02 AM
Kemicalburns's Avatar
Kemicalburns
if they are stock 8" wide rims then the backspacing is a little incorrect. your lift had is using the stock radius arms and drop brackets correct and thats what the tires are rubbing on.
just to let ya know i have a 6" with extended arms and they even have the offset but because i am using the stock 8" wide rims instead of 10" wide rims they rub as well.
so you either get used to it or buy some new rims with less back spacing .
Old Oct 26, 2005 | 09:54 AM
bgblktruk's Avatar
bgblktruk
Sorry I forgot to add I have the extended radius arms. They aren't stock but to the best of my recollection they are 8".
So my only option is new rims? Well the only good thing about that is I've had my eye on a couple other styles for awhile.
Thanks
Mike
Old Oct 26, 2005 | 10:01 AM
skelator84's Avatar
skelator84
I have a bone stock suspension and am running 32x11.5 on and 10x15 rim, i do have tire rub but only when making very tight turn. i can turn aroung on a residential street without hitting the curb so i didnt figure it would hurt anything to leave it alone.
Old Oct 26, 2005 | 10:40 AM
Kemicalburns
3.25-3.50 backspacing would be best i believe. try a search just incase . also ask who your buying the rims from.
