Aerostar Ford Aerostar
4.0 Harsh engine rattle
Old Oct 25, 2005 | 11:32 PM
428_cobra_man's Avatar
428_cobra_man
Has anyone ever experienced a Loud Crackling noise under hard-High RPM acceleration, my 92 4 liter does this when I tramp the pedal or accelerate hard to pass, it sounds almost like shaking a marble around violently in a tin can, The motor has 345,000 KM on it, runs excellent good oil pressure no ticking or anything else, I am sure it is not rod bearings, I was thinking maybe oil pump? or timing chain noise? anyway it bothers me as it sounds really harsh with the doghouse taken off, if anyone knows what it could be let me know
(I wonder if maybe it isnt piston slap?)
Old Oct 26, 2005 | 05:49 AM
96_4wdr's Avatar
96_4wdr
pre ignition aka pinging...search Aero forum
usually caused by carbon build up on top of pistons and combustion chamber...can be caused by too high a heat range of spark plug...or low octane fuel
fuel mixture ignites explodes prematurely before ign spark...carbon heats up and supplies ign source.
run a couple cups of water thru vacuum line while engine hot and at 2000 rpm
or use a can of Seafoam into vacuum line...
shows up mainly on high mileage engines.
dangerous to long engine life..can crack heads...bend rods..crack pistons
Old Oct 27, 2005 | 02:02 AM
428_cobra_man
I think you are right, I will try the water thing and , Ill also put 20 bucks of High Octane gas in and see if it helps.
Old Oct 27, 2005 | 03:27 AM
96_4wdr's Avatar
96_4wdr
usually high octane gas will not help with a point source buildup of carbon, like having a burning match in the combustion chamber when the engine is warm..boom
no spark plug needed
if water injection does not help...check base timing with timing light...may have failing worn cam position sensor or its drive gears
Old Oct 31, 2005 | 03:58 AM
428_cobra_man
I tryed the water thing... about 2 quarts of water through the brake booster hose.... It worked Incredibly well. the van idles smoother now and no longer pings or rattles I am very impressed. While i was accelerating hard to test it I noticed that My oil pressure drops to nothing At WOT, at idle its good... hmm something else to bug me!
Old Oct 31, 2005 | 04:15 AM
96_4wdr's Avatar
96_4wdr
probably a chunk of oil breakdown crud plugging port of oil pressure sender, oil pressure goes up on WOT pressing chunk tighter into opening, replace sender
on hot engine next oil change, add to crankcase, 2 quarts of Rislone, diesel or kerosene in crankcase, run engine for 1 minute to stir with oil, shut off and let set overnite to digest crud in crankcase.
Old Oct 31, 2005 | 12:18 PM
copper_90680's Avatar
copper_90680
On the 4.0L, replacing that sender ranks right up there in my book with the spark plug replacement Not much room, power steering pump is in the way, must do it by feel, unless you are a Jedi and the Force happens to be with you that day
Old Oct 31, 2005 | 12:55 PM
96_4wdr's Avatar
96_4wdr
Hans Aero and the Star Falcon
rich1brad
Mar 23, 2021 07:03 PM
JMWRIGHT335
Aug 27, 2013 02:17 PM
mrjc
6.7L Power Stroke Diesel
Sep 25, 2012 10:59 PM
7.3 Ex
Dec 31, 2011 02:06 AM
7.3 Ex
Mar 13, 2011 06:27 PM
