Aerostar Ford Aerostar
Just bought a '96
Old Oct 29, 2005 | 09:21 PM
99f350sd's Avatar
99f350sd
Just bought a '96
My 94 has rust holes in the frame so it was time to get the wife a new one..
This 96 awd xlt is like new 80k miles and its scary cause there's little evidence it was used much, lucky me..I have a few things to fix the coolant gauge doesn't go up. I get heat though. Sensor no biggey. I'm gonna do all the fluids and stuff.
Question did they change anything going from 94-96?
Thanks guy's
Dick
Old Oct 29, 2005 | 11:34 PM
96_4wdr's Avatar
96_4wdr
OBDII advanced engine computer control PCM system, heads changed on 4L, tranny is a totally electronically controlled 4R55E version of A4LD
enjoy
Old Oct 30, 2005 | 09:33 AM
99f350sd's Avatar
99f350sd
What would cause the speedo to move slightly at 60 mph up or down 1 mph. My 94 doesn't and I think the cruize is affected by it. I'm guessing speed sensor in the tranny somewhere. Maybe its dirty etc.
Old Oct 30, 2005 | 09:42 AM
96_4wdr's Avatar
96_4wdr
top of rear diff. pumpkin, do fail, also affects RABS ABS, auto tranny shifting
look for corrosion in connector
Old Oct 30, 2005 | 10:20 AM
99f350sd's Avatar
99f350sd
Just like a super duty..
Thanks
Old Oct 31, 2005 | 01:39 PM
93nighthawk's Avatar
93nighthawk
Congrats in staying in the Aero Family!
Sounds like a good find!
Old Oct 31, 2005 | 05:50 PM
B-Aerostar's Avatar
B-Aerostar
I hope I have such luck to get another when mine is ready to go.
Old Oct 31, 2005 | 06:20 PM
fud24682000's Avatar
fud24682000
Electronic trannie
Pertinent to this thread, exactly what year did they go to the electronic trannie on Aeros? I want a later model van but would want to avoid an electronic one.
At the same time I'd want one new enough to have a tougher A4LD than the earlier vans had.
Ray Mac
Old Oct 31, 2005 | 06:40 PM
96_4wdr's Avatar
96_4wdr
97 has the heaviest duty most rugged tranny, most of the bugs had been worked out by then, most of the large thrust bushings had been replaced by Torrington roller bearings, band breaking problems had been worked out, toughtest bands, improved clutch packs with better friction material and grooved design for better engagement, stronger drums.
one has to remember, the A4LD/4R55E/5R55E started design life as the Pinto C3 3 speed rated for less than 100 hp by Ford France, an almost 30 year old design. later variants ended up behind more than 200 hp and 3 times the torque.
95 was the last "mechanical" A4LD but it does not have all the later goodies
Old Oct 31, 2005 | 07:39 PM
fud24682000
Thanks.
Do these upgrades apply to both the 2WD and 4WD vans?
Old Oct 31, 2005 | 09:02 PM
99f350sd's Avatar
99f350sd
Anyone know what the torque is on the thermostat bolts on the 96 4.0L Can't find my darn manual. I just ordered a cd..
Old Oct 31, 2005 | 09:33 PM
B-Aerostar's Avatar
B-Aerostar
Thermostat housing bolts torque 12 - 18 lbs ft
Old Oct 31, 2005 | 09:47 PM
93nighthawk
If memory is correct it is around 15 ft-lbs. You don't want to force it, otherwise you will be cussing trying to get the rest of the bolt out.
Yes, 96 both 3.0 and 4.0 had the 4r44e where the 97 has the 4r44e for the 3.0L and 5r55e for the 4.0L.
