It's a 77 1/2 ton 4x4, 4spd and I have abit of an exhaust manifold issue. I can get no headers to fit and I dont wanna spend money to have some fabbed but here's the problem. Engine is from a '68 Torino GT....being as it has the car heads getting something to bolt up is a problem in itself. The driver side manifold exits right by the clutch linkage and has no room to even bend exhaust pipe for it. Anyone know where I can get a manifold that exits down like a blockhugger type thing? Something that matches that passenger side.
Take a look at my gallery under "headers 101" and see what you think. This is a set of Sanderson headers that are originally made to fit the 351C engine but as you can see they are mounted on a 400 in a '77 F150 4x4.
link no work. my biggest problem is no one's headers fit....i've tried several, called companies and they dont work for my application. I wish I could get some nice tri-ys made for it buuuut...too much green.
sorry it should have worked, I went to ebay and typed in 390 headers, and it had a sit of longtubes for 73-79 ford trucks.They are used but cheap price.35.00
sorry i found some more ehaders for ford trucks fe headers for trucks i went to ebay and also typed in fe headers and it brought up some more, they are pretty cheap so you might wnat to check it out, ive ordered online thru ebay and its pretty good.
