Bad Idling
The Problem Is That When Is Cold In The Morning It Doesnt Idle Very Well,(didnt Idle High)dont Reach 1500rpm.(it Goes Up And Down)alone.
Very Low In The Morning.and While Using It (warm Motor)it Runs Ok When You Pass The 2000 Rpm.
It Has 220k And Its All Original.(o2 Sensor All Original)
HOW CAN I DO TO VERIFY MY O2 SENSORS??
The Only Thing That Y Change Where Plugs,rotor And Cables.
Thanks A Lot.
If you don't find anything there try checking for vacumn leaks and cleaning the IAC.
