Down shifting redline?
Old Oct 25, 2005 | 09:40 PM
DoubleUFarm's Avatar
DoubleUFarm
Unhappy Down shifting redline?
This last weekend I was towing a 9,000lb trailer down a 6% grade with my 05 F350 6.0l. I was in tow haul mode decending the grade at 70mph. I applied the brakes to slow down for a corner when the trans downshifted and shot the RPM's to 3,700. Is this normal?
Old Oct 25, 2005 | 09:48 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Absolutely.
3700 RPM is totally harmless.
Old Oct 26, 2005 | 12:04 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Welcome DoubleUFarm...
Check this thread out if you own a 6.0l
https://www.ford-trucks.com/forums/s...d.php?t=303583
All you ever wanted to know (and then some)
Old Oct 26, 2005 | 06:43 AM
IB Tim's Avatar
IB Tim
Isn't the TH mode cool....saves on breaks ...yes breaks
Old Oct 26, 2005 | 01:25 PM
jackofalltrades's Avatar
jackofalltrades
6% grade. 3 miles. Loaded truck. About 7,000 lbs for the camp trailer. Decelerating, 4th gear, compression braking. Never went over 62mph with very few taps on the brakes.
Lets see... Thats maintaining about 1,200 less RPM, than with the Torque shift. Not to say that what the TS does is bad. I think it's a great concept. But anything less than getting near redline, decelerating, which is just as damaging as full throttle at the same R's, is more appealing to me.
So, tell me, when using Tow/Haul, will it actually drop two gears at a time? To me that's a massive RPM and reverse torque change on drive train components.
Do most of you relly on Tow/Haul, without the use of brakes?
-Steve
Old Oct 26, 2005 | 03:11 PM
DoubleUFarm
I agree! Having the truck downshift to near redline is not desireable. The truck was in 4th holding arount 2750 rpm when I tapped the breaks it down shifted into 3rd. I immediately took it out T/H, almost as a reflex, and was expecting a piston to come through the hood. I hope Ford Engineers know what they are doing!
Old Oct 26, 2005 | 03:31 PM
SpartanDieselTech
Former Vendor
They do....
I've wrapped the tach needle around the peg (literally) more than a few times on upshift, and it has never done any bottom end damage or valvetrain damage. IMO it would take well over 6000 rpm to actually force parts to fly. These are very rev-tolerant engines, especially being diesels.
Old Oct 26, 2005 | 05:33 PM
Daryl Hunter's Avatar
Daryl Hunter
I tow a 10,000 - 12,000 lb 30' Toy Hauler trailer up and down the grades around Southern California and have also hauled it up/down the continental divide.
Use the T/H mode all the time and never had the tranny downshift into redline on its own or through my tapping of the brake. Generally on anything less than a 6% grade the tranny will hold back the trailer OK without further use of the brakes. On some of the steeper grades I will have to add some additional truck/trailer braking now and then.
Mostly I just have to do the extra braking at the end of a straight section for a turn that is tighter than my current speed, i.e., I'm doing 45 MPH and the tranny is holding back just fine at that speed, but the upcoming turn is advised as 30 MPH, then obviously I need some more brakes.
I'm really happy with the function of the T/H mode.
As far as I can remember from the owner's manual, the redline is 3900 on upshifts though the tranny and engine management will never shift or rev that high in stock trim. The mechanical redline for downshifting and tranny holdback is something like 4300 or 4500 I believe.
kissfan79
Feb 20, 2014 11:34 AM
WRABER
Dec 1, 2013 08:29 PM
tomfrey
Aug 15, 2010 05:01 PM
Shark55
6.4L Power Stroke Diesel
16
Aug 15, 2007 12:15 PM
Motorcraftsman
Apr 10, 2001 11:20 PM
