swapping a 302 in
Old Oct 25, 2005 | 05:00 PM
chris12's Avatar
chris12
swapping a 302 in
What does it take to swap the 302 into a 6cyl Ford F150. Other then changing the mounts and hoses.
Old Oct 25, 2005 | 07:12 PM
Franklin2's Avatar
Franklin2
Flywheel or flexplate needs changing.
And about the mounts. I don't know if you realize the frame perches for the mounts need to be ground off, and v8 perches installed.
Your throttle cable needs changing.
Little bits and pieces of the wiring need to be modified.
Old Oct 25, 2005 | 07:15 PM
chris12's Avatar
chris12
Don't the motor mounts bolt on and off from the mounts welded on the frame. If so then all i would have to do is bolt my 302 mounts up to the mounts on my frame correct
Old Oct 25, 2005 | 07:16 PM
ford390gashog's Avatar
ford390gashog
you are going backwards by swapping a 302 in place of a six.
Franklin2's Avatar
Franklin2
Nope. You have to change the frame brackets. After you change to v8 brackets, then yes, all the different v8 motor mounts will bolt and unbolt.
Old Oct 25, 2005 | 07:18 PM
chris12's Avatar
chris12
ok no problem just cut em and re weld them..
Thanks
Old Oct 25, 2005 | 07:19 PM
chris12's Avatar
chris12
why is that going backwards
Old Oct 25, 2005 | 08:20 PM
Franklin2's Avatar
Franklin2
Some people have the opinion that the six is a more suitable engine in a truck than the 302. If you think about it, there is not much difference in displacement between 300 and 302.
So the difference is the six is a low rpm long stroke engine for better pulling while the 302 is a shorter stroke higher rpm engine.
It all depends on what you want to achieve with your truck, but I have to admit I had a 302 in my 4x4 long bed 1980, and it was barely enough when pulling a trailer sometimes. I have a 351w now it is way better pulling a trailer than the 302, all things being equal(gearing, etc.).
