Manual Safety Switch
Old Oct 26, 2005 | 05:36 PM
User 71024's Avatar
User 71024
Originally Posted by 1975Ford
Do you got any pictures of the custom work you have done. Thanks.
No but if you snap a pic of the upper portion of your clutch pedal I can probably spec it out for you.
Old Oct 26, 2005 | 05:54 PM
1975Ford's Avatar
1975Ford
It's like Mil1ion said "At the top -middle of the firewall there should be a grey connector. This contains the NSS wiring." use these wires to setup the clutch pedal connector switch.
Old Oct 26, 2005 | 06:32 PM
User 71024's Avatar
User 71024
I did a quick search on google and came up with this, it looks very similar to the GM switch I am talking about, you just have to mount it so the button is depressed when the clutch pedal is up.
http://www.jhps.com/Merchant2/mercha...ode=Electrical
Old Oct 26, 2005 | 11:52 PM
Mil1ion's Avatar
Mil1ion
JD,
Here are two systems Ford Used.
https://www.ford-trucks.com/user_gal...=93334&width=0
The bottom one is an 79 version.
