Is that a replaceable part? Or do I need to swap out the cluster? I just bought one, but when i got it home, the back crumbled in several of the bulb holes. Which is par for the course on these old trucks.
And while we are on the topic of dash lights, can you take the green filter out of the heater control light?
After messing with it for a while I said screw it and bought a 3 gauge set. Voltmeter, oil and water. My question now is how to wire up the dimmer for the lights. And where should I tap into for the Voltmeter? The fuse box? or can I use another keyed ignition wire?
