Sponsored by: Auxito
Motor won't start
Old Oct 24, 2005 | 06:38 PM
JBeebe323's Avatar
JBeebe323
Red face Motor won't start
I have a 1998 ford f150 4.6L motor first it wouldn't start with the key so we had to jump the starter to get it going worked fine like that for a month then now it just turns over and will not start. The fuse to the pcm keeps blowing. Can anyone help me I am a girl?
Old Oct 25, 2005 | 06:58 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Moved and member notified
Old Oct 25, 2005 | 05:23 PM
lancekilgore's Avatar
lancekilgore
sounds like you have a GEM problem, or a major wiring problem, check for loose or damaged wires, exposed wires, a blowing fuse tells me you have a positive wire grounding out, or it could be a bad relay.
Lance
Old Oct 25, 2005 | 06:47 PM
peppermrj's Avatar
peppermrj
Maybe this thread will help. https://www.ford-trucks.com/forums/s...d.php?t=369404
