Bronco II Ford Bronco II
2.9 mystery problem
Old Oct 24, 2005 | 03:04 PM
comochja's Avatar
comochja
2.9 mystery problem
I need help diagnosing a problem with an 86 2.9 AOD. It starts fine, runs great for 1 - 1 1/2 minutes, then starts missing and running rough. It will shut off if its idling, but if you are driving, you can give it more pedal and it will "push through" the roughness and run fine again. This happens at each cranking, but never more than once. This is a beater truck used only 1-2 times a month. HELP
Old Oct 24, 2005 | 07:27 PM
Ken00's Avatar
Ken00
Have you given it a tunup, pulled the codes, tested the fuel pressure?
Old Oct 25, 2005 | 04:30 PM
comochja's Avatar
comochja
Thanks, just saw the link to pulling codes in another post. I'll do that on my next free time (this week aint looking good) and see what comes up.
