Squeaky Chassis
Old Oct 24, 2005 | 07:16 AM
J7Bones's Avatar
J7Bones
Squeaky Chassis
Hi. '95 Ranger 2.3L 4-cyl. 5-speed.
I hear quite a bit of squeaking during highway driving. Is there a lube/oil I can get to quiet it down a bit? It definitely sounds like its coming from the frame around the lower passenger side and also the upper driver side of the cab.
Where do I apply the lube/grease/oil?
I was under the impression that Jiffy Lube/Valvoline/Grease Monkey and the likes greased the chassis as part of the standard service...Guess I was wrong!
Thanks.
Old Oct 24, 2005 | 08:04 PM
Ken00's Avatar
Ken00
If it sounds like it's were the frame and cab meet then I would suspect the cab mounts are bad and nothing but replacing will stop it.
Old Oct 24, 2005 | 08:30 PM
Rockledge's Avatar
Rockledge
There are no chassis lube points on your Ranger, no grease zirks, nothing like that. So in fact, all the Quick Lube places can do is change your fluids.
Old Oct 25, 2005 | 07:25 AM
J7Bones's Avatar
J7Bones
Thanks fellas. I'll check into the cab mounts. Do you know the approx. cost?
Old Oct 25, 2005 | 08:29 AM
SuperBlue's Avatar
SuperBlue
If the mounts aren't too worn you can spray them with amour all or some similar product and bandaid it for a bit.
Old Oct 25, 2005 | 10:18 PM
Detret's Avatar
Detret
You might want to try Sea Foam , I use it on my 2001 4.0 , I got it Auto Zone for about $6.00 . Good stuff .
Good Luck , detret .
