2wd to 4wd?
Old May 5, 2002 | 09:11 PM
ford_boy4819's Avatar
ford_boy4819
2wd to 4wd?
o.k.. it"s like this.. i have a 79 2wd f-150 and i want to make it 4wd..i have all the running gear( frt and rear end, tranny and transfer case) from a 79 4wd, is it as simple as drilling a few holes and bolting the front end on to my frame?.. obviously the rear end will bolt right up where the old one came out..i"m just wondering if the 2 frames are exactly the same?...any help would be great thanks...PAUL...
Old May 5, 2002 | 11:21 PM
Jermafenser's Avatar
Jermafenser
2wd to 4wd?
Nope.
Shift the body from the 2wd truck to the 4wd frame. Doing that - You'll still have to do a lot of work.
Old May 6, 2002 | 12:03 AM
leftboot's Avatar
leftboot
2wd to 4wd?
Hey what about a F250 2wd to 2wd? How much work involved?
Thanks,
Ryan
Old May 6, 2002 | 09:07 AM
ford_boy4819
2wd to 4wd?
can you tell me what the difference is in the 2 frames?...paul..
Old May 6, 2002 | 09:53 AM
Vampiro's Avatar
Vampiro
2wd to 4wd?
theres a artical about converting 4x2 to 4x4 here. it's a lot of work pal! it'll be easier just to fix up a 4x4
Old May 6, 2002 | 03:06 PM
leftboot's Avatar
leftboot
2wd to 4wd?
Yea mine was supposed to read 2wd to 4wd not 2wd to 2wd!
Thanks though!
Ryan
Old May 6, 2002 | 03:33 PM
ford_boy4819
2wd to 4wd?
o.k then, how much work is involved in switching the cab from the 2wd frame to the 4 wd frame?...surely the cab mounts on both frames must be the same?...i mean there the same year truck, just one is 2wd and the other is 4wd...paul...
Old May 6, 2002 | 03:37 PM
ford_boy4819
2wd to 4wd?
vampiro, that article you refer to is converting an 80 to 86 f-150..which has a totally different front end set up than the 79"s.... thanks for the info though...
Old May 8, 2002 | 02:29 AM
fordmando's Avatar
fordmando
2wd to 4wd?
Nope, all the different frames have extensions in the appropriate place to fit the same body. That is to say, they make the frames fit universal bodies, rather than having special bodies than go with certain type frames. It's much cheaper to make one body type, the frames and springs are what makes them a 150, a 250, or a 350 (or even bigger, with different fenders.)
fordmando
70 F-100 460 C6
78 F-150 4x4 400 NP435
George Selby
Old May 8, 2002 | 03:04 PM
ford_boy4819
2wd to 4wd?
so i can take my 2wd cab and bolt it right on the 4wd frame?...thats great news...i was starting to get a little scared there...lol...thanks fordmando...
Old May 8, 2002 | 04:24 PM
dfisher1's Avatar
dfisher1
2wd to 4wd?
1Badxj
Jun 2, 2014 10:33 PM
mamatried
Sep 10, 2013 05:21 PM
66f250
Jul 1, 2013 07:43 PM
Sugarmommaracing
Sep 18, 2011 10:32 AM
plapczynski
Mar 1, 2005 06:14 AM
