DTC code P1405
Old Oct 23, 2005 | 06:04 PM
fordtrucklover94's Avatar
fordtrucklover94
DTC code P1405
4.0L OHV V6 Explorer Sport 4x4
Was driving to work and the light popped up, so after work i stopped at advance and had them pull a code for me, the code that popped up reads as follows:
DTC (Codes)
P1405
Manfacurer Contrl.
Auxiliary emission
Controls
Naturally the guy at advance stood there, dumbfounded, had no clue what was what. What does this code mean, how can I fix it? Thanks for ya'lls help.
Old Oct 23, 2005 | 07:05 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Exclamation
FTL94, code 1405 is : "Differential Pressure Feedback EGR (DPFE) Sensor Upstream Hose Off or Plugged."
The DPFE sensor is located on the driver's side of the engine, about halfway down the bank. Check for a loose or cracked vacuum hose. The code says it's the upstream hose, but I'd check all of them.....
TLR
Old Oct 23, 2005 | 07:22 PM
fordtrucklover94
Thanks, i'll make sure i check that in the morning before I head out. Appreciate your help.
Old Oct 24, 2005 | 08:46 AM
fordtrucklover94
sure enough, that hose has had it, the other hose looks to be fine, but i might just replace it bc it might not last much longer itself, thanks.
Old Oct 24, 2005 | 02:53 PM
Jharger's Avatar
Jharger
I got this omce on my 93. Line just popped off so I tie wrapped clamped it down. When you replace these, ask for high temp EGR line, not vacuum line. I think it's silicon rubber.
Old Oct 24, 2005 | 07:50 PM
thelonerangerxlt
Thumbs up
It's great when a fix is that simple and easy. Usually those DTC codes aren't that specific, but this time it certainly was. Good job.
Good tip from Jharger on using high-temp hose. EGR stuff gets
very hot.
the deno
Jun 21, 2013 01:53 PM
cabo169
1983 - 2012 Ranger & B-Series
Apr 28, 2009 06:54 PM
mikerocks26
New Member Introductions
Oct 20, 2008 02:15 PM
DeanG
1997 - 2003 F150
Mar 24, 2006 02:33 PM
redray59
Dec 10, 2003 06:24 AM
