Advice on changing spark plugs.
Old Oct 23, 2005 | 04:39 PM
riverjig's Avatar
riverjig
Exclamation Advice on changing spark plugs.
I am changing my spark plugs on my 99 ranger 3.0. Is there anything other than the norm I should watch out for? any tips? I read somehwhere that there are two types of spark plugs. One set for each side of engine. I alsoi would like to know how to clean the carb and change injectors. I removed my intake and I looked inside the carb and it was filthy. I am purchasing a K&N kit next week and want to clean it by then. It also says on the carb" has special coating........do not clean". Please help.,
Old Oct 23, 2005 | 04:54 PM
mightypan42's Avatar
mightypan42
Carb? Throttle body perhaps?
Old Oct 23, 2005 | 05:09 PM
RangerPilot's Avatar
RangerPilot
throttle body cleaner can be used on it. It's designed for the coating.
Old Oct 23, 2005 | 06:27 PM
Rockledge's Avatar
Rockledge
Use motorcraft plugs. Only the plugs from the factory are different. The OEM replacements are all the same, so just chekck the gap and pop them in.
Fuel injectors are not a maintenance item, leave them alone. At most, you might run a bottle of fuel inection system cleaner through the fuel tank.
Cleaning Your Throttle Body
Old Oct 24, 2005 | 07:25 PM
frdrngrlvr's Avatar
frdrngrlvr
i'm pretty sure your not carburerated. i found out the hard way that mine didn't like anything else other than motorcraft plugs. look in the owners manual for the p/n. and as far as injectors, if you use decent gas they should be ok.
Old Oct 25, 2005 | 04:32 PM
jinx102672's Avatar
jinx102672
If available, use compressed air to blowout the area around the tops of the old plugs before removing them. It will help get some of the dirt and grit away form the opening when you remove the plugs.
Old Oct 30, 2005 | 01:25 PM
riverjig's Avatar
riverjig
Red face Correction......?
I went with the Autolight plugs and some new wires. I forget what a difference it makes. My truck went from hero to zero. And yea, I stand corrected, I said carb, meant throttle body. Thanx for the advice. Oh yea, I wrote that I was having major troubles earlier with my truck running. It was basically at what felt like half power. When I went to remove the plug wires, one of the electrodes had been seperated from the wire and wasnt making conrtact. This has corrected my fuel economy problem(duh), and all the details I now consider obvious with this sort of problem.
Old Oct 31, 2005 | 05:24 PM
frdrngrlvr's Avatar
frdrngrlvr
yea autolites are crap! i don't know what vehicle runs good with them but i know rangers don't.
Old Oct 31, 2005 | 05:31 PM
RangerPilot
For plugs, just stick with the Motorcraft OEM plugs. They work great.
I know other brands work just fine. Some people want others, fine go for it, just make sure it'll work.
Old Oct 31, 2005 | 06:19 PM
Rockledge's Avatar
Rockledge
Autolite, a division of Honeywell, actually makes Motorcraft plugs.
A while back a Ford Tech and fellow FTE member emailed Honeywell and asked whether they also made Motorcraft plugs. Here is the response he got:
"As a division of the Honeywell Corporation, Autolite is the manufacturer responsible for the production of all Motorcraft spark plugs in North America for the Ford Motor Company. Both Autolite and Ford/Motorcraft spark plugs are built to quality standards using quality components. Autolite manufactures the Motorcraft plugs based on the specific design requirements of the Ford Motor Company. Autolite and Motorcraft spark plugs are manufactured side-by-side at our facility in Northern Ohio."
If there are differences in the plugs, it is because Ford probably requires that the Motorcrafts conform to tighter specs.
Old Oct 31, 2005 | 06:33 PM
RangerPilot
I stick with Motorcraft until I find a better brand.
Old Nov 1, 2005 | 07:08 PM
frdrngrlvr's Avatar
frdrngrlvr
my experience with autolites was very disapointing. i went to the local parts store one day for some spark-plugs and asked for motorcraft. they were out. so i opted for what they had, autolite. i gapped them to spec. installed them and off i went. the worst 400 miles my poor ranger ever went through followed. i really thought i screwed up one of the boots on the wires so i bought new wires but it still ran like crap! so i went back and got the motorcraft plugs that they were out of and walla, smooth as can be! so i would have to say that the motorcraft plugs must be made to higher specifications and the autolite are the bottom of the barrel.
Old Nov 1, 2005 | 08:42 PM
Rockledge's Avatar
Rockledge
I've seen posts from others who share your opinion. In fact, I've read about many more instances where using anything other than Motorcraft plugs has led to problems in Fords. Bosch spark plugs are probably the most famous for working poorly in Fords, and Champion is not that far behind. (Of course, there will be people who swear by the Bosch plugs in their Fords, but lets not go there now).
IMO, one of the reasons a lot of Fords have issues with anything other than OEM-spec plugs is because of the DIS/EDIS ignition sytems, which are of the "waste spark" design. For one thing, the plugs in these systems actually fire twice as often as in other systems. See: Ford DIS & EDIS Ignition Systems
Old Nov 2, 2005 | 01:49 AM
frdrngrlvr's Avatar
frdrngrlvr
well i'm glad you didn't take my statement offensive. i really did have an awfull experience, i could barely believe it. i used to be a die hard gm guy , sorry. i also used nothing but ac delco stuff and fram ( yea, i'm that guy). the thing was gm seemed to work ok with that. my ranger is the first ford i've ever had and i ain't lookin back! but what i'm realizing is that it really don't like much other than motorcraft. right now i'm in need of an alternator so i'm guessing motorcraft but i know its gonna be big $. that is the downfall. however i think the goodyear (gator-back) serpentine-belt is better constructed than the motorcraft. by the way, i only use motorcraft oil-filters thanks to you guys!
Old Nov 2, 2005 | 07:18 AM
BarnieTrk's Avatar
BarnieTrk
Fellas:
The local parts store dude suggested that I consider (for my '94 2.3L 4-banger) to switch from the OEM platinium plugs (Motorcraft AWSF32PP) to an less expensive non-platinium "equivalent" plug replacement? Any thoughts or experiences with doing this?
I realize that the non-platinium plug won't last as long - but I pull them out and check their gap & 'never-seize' the threads twice a year anyway. At less than half the price of platinium plugs, I was wondering if anyone else has done this and faired well or not........
Thanks!
BarnieTrk
