97 Ranger multifunction switch
Old Oct 23, 2005 | 02:13 PM
jdwheels's Avatar
jdwheels
Anybody have the replacement procedure for the turn signal
switch replacement?
Thanks
Old Oct 23, 2005 | 02:22 PM
HomerWinzlow's Avatar
HomerWinzlow
If it has tilt steering start by unscrewing the tilt lever from the columb. There is a flat spot on the lever to use a tool to loosen it. Then remove the screws at the bottom of the columb shroud to remove the shroud. The ignition lock cylinder can then be removed to take off the top half of the shroud. Place ignition in On position and insert a narrow tool in the hole at the bottom of the cylinder tube through the hole which the lock cylinder retainer resides. Push to release lock cylinder and set cylinder aside. You can work around removing the lock cylinder but the shrouds will be somewhat in the way. Then use a #20 Torx screw driver to remove the two retaining screws on the multifunction switch. Carefully remove the two electrical connectors from the switch and replace the switch. Installation is reverse of removal.
Old Oct 24, 2005 | 07:25 AM
pawpaw's Avatar
pawpaw
Remove the battery B- cable, before you begin dis-assembly!!!!!
Old Oct 24, 2005 | 03:23 PM
jdwheels's Avatar
jdwheels
Thanks guys, will give it a try
Larry Grimes
Nov 24, 2014 04:39 PM
97 HD
2004 - 2008 F150
Aug 4, 2009 03:56 PM
AlaTex
Jan 5, 2007 10:19 PM
puck1263
Aug 9, 2006 08:45 PM
mantta
Jun 13, 2002 05:45 AM
