Sponsored by: Real Truck
1994 sd map sensor
Old Oct 23, 2005 | 11:37 AM
zoom1954's Avatar
zoom1954
1994 sd map sensor
Trying to locate the map sensor on a 1994 super duty chassis in a rv. need help
Thanks
Old Oct 23, 2005 | 12:43 PM
99f350sd's Avatar
99f350sd
Its gonna have a vacuum line to it and a 3 or 4 wire connector. Usually black plastic not much bigger than 1/2 a cig pack. So trace vacuum lines and you'll hopefully find it.
Dick
Old Oct 23, 2005 | 01:59 PM
zoom1954's Avatar
zoom1954
found it, thanks, and boy I hope I finally solved my big problem. I have had intermittent running problems, usually at take off. Spitting and stalling and then would run ok, but the power never seemed right adn gas mileage was terrible. I just replaced the MAP sensor and while I still have a hard to start issue, once it did it runs great and the power is unbeliveable. Hopefully once it gets hot I will still have no issues.
Gene W
Sep 10, 2024 04:21 PM
Karl Rein
Jun 9, 2013 12:29 AM
lghilton
New Member Introductions
Jun 14, 2006 11:02 AM
nfs-nunavut
Apr 23, 2006 09:51 AM
CPE
Jun 22, 2003 06:39 PM
