Sponsored by: Real Truck
TBC Fault??
Old Apr 2, 2005 | 03:56 PM
vansoutriding's Avatar
vansoutriding
Question TBC Fault??
My 2005 has towcommand and this fault is addressed in the owners manual..It only flashed on my dash 6 different times during the coldest of weather (-15f). I was not towing anything, just driving to work. There did not seem to be any lasting problem after the cold weather broke. Of course the truck is under warrantee but I have not had a chance to get it in. Any one else have this TBC fault notice when you weren't towing? Once tax season is over I will get my baby in for its first look-see at the dealers.
Old Oct 11, 2005 | 06:16 PM
chadmerrill's Avatar
chadmerrill
TBC Fault
Did you ever resolve your TBC fault indicator. My 06 350 PS is brand new and occationally right at start up I get the TBC fault indicator flash briefly. It only happens once and a while.
Just curious if you go any information on you TBC fault.
Thanks
Chad
Old Oct 11, 2005 | 07:50 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Chad to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 11, 2005 | 08:12 PM
vrsc's Avatar
vrsc
Thanks
Chad
I have been having the same problem/issues since day one. The TBC fault sometimes comes on during start-up for no reason. No towing
Old Oct 16, 2005 | 01:40 AM
bajaron's Avatar
bajaron
Lightbulb TBC fAULT
Well i have the same problem with my 2005 f350. The message center started showing tbc fault. I took it in to the dealer and they said it had to do with a 2 amp fuse under the hood. So they fixed it and i took it home.
Well when i drove it the next morning and it flashed TBC Fault again so back to the dealer the next day. They have had the truck for two days and still havent fixed it. I broght it home for the weekend and will gave it back to the dealer on tuesday. Anyone kmow the the fix for this. ???
Thanks
Ron W.
Old Oct 16, 2005 | 09:35 AM
05bluehog's Avatar
05bluehog
This fault popped up once for me on the road... but could not duplicate. It went into the dealer for some minor issues and popped up for them. Here is what the Invoice says:
TRAILER BRAKE WARNING IS COMING ON DISPLAY IN CLUSTER TEST DROVE AND VARIFIED TRAILER BRAKE COMING ON WHILE DRIVING. CHECKED CODES. FOUND CODE C2803 BRAKE PRESSURE TRANSDUCER SENSOR CIRCUIT FAILURE. PERFORMED PINPOINT TEST AS PER MANUAL. MONITERED BOO PID. FOUND CHANGING WITH BRAKE PEDAL APPLICATION. CHECKED BRAKE PRESSURE SWITCH. FOUND OK. CHECKED CKTS 3600.3601.3602 FOR SHORTS AND FOR OPEN. FOUND OK. CHECKED CKT 3602 DOE VOLTAGE. FOUND IN SPECS. NECESSARY TO REPLACE MASTER CYLINDER AS PER PINPOINT TEST. REPLACED MASTER. CLEARED CODES. TEST DROVE. RECHECKED. NO CODES PRESENT. ALL OK AT THIS TIME. USED MTIME TO R+1 INSTURMENT PANEL CENTER FINISH PANEL TO ACCESS CONNECTOR C1445.
Parts - 1 5C3Z-2140-HA Cylinder Asy
4 PM-1 Fluid - Brake
Have not had any issues since. Hope this helps.
Old Oct 23, 2005 | 02:29 PM
bajaron's Avatar
bajaron
05bluehog
Thanks for the info. i will bring it with me when i take the truck in. Sorry for the delay in response to your answer
Ron W
phatboy7
Jun 14, 2020 12:33 PM
Rotterdam24
Oct 20, 2016 07:23 PM
Acekris13
6.4L Power Stroke Diesel
Jun 14, 2016 04:56 AM
mnmwhit
Dec 16, 2012 01:56 PM
PogueFord
2004 - 2008 F150
Dec 14, 2010 05:41 AM
