Hard shift into reverse
Old Oct 23, 2005 | 12:42 AM
Tjax's Avatar
Tjax
The C6 I just swapped in really shifts hard into reverse. Everything else is OK. Sometimes it goes in smooth, buy mostly really slams into reverse. Any clues?
Old Oct 23, 2005 | 12:45 AM
plowpusher's Avatar
plowpusher
idle to hi reverse gets a ton of pressure if the ldle is to hi it will slam in
Old Oct 23, 2005 | 12:49 PM
Tjax's Avatar
Tjax
Idle seems fine. Would not having the Carb kickdown hooked up cause the higher pressures?
