Leaking Power Steering Fluid??
J
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
If you have a hose leak at the connector I think I read you have to replace whole hose because the seals are not replacable seperately, but I may be wrong.
1) If it's not leaking now, it will
2) If you try to replace it yourself, you are in for hours of frustration, after which, whatever you didn't replace will then apply rule #1
3) Do the whole system at once & save yourself many, many future headaches, along with, in the long run, some money
My first leak was in the return line. Replaced the return line.
Second leak was at the pump, from the pressure line. Not easy or cheap, so I fed it stop leak.
Third leak was from the rack & pinion unit. Also not easy or cheap, so I fed it more stop leak.
Ultimately, both lines, the rack & the pump needed replacing. Since it had other issues at the time, I traded it for a newer one.
Seriously, unless you have experience doing this, or a LOT of patience, take it to a shop & let them have the headaches. It's not going to be cheap, but if you have to replace one part, and you don't replace the rest of it, including all the fluid, you're just going to end up having to do it later. Doing one piece at a time, you can also end up having to replace the same part more than once.
A PS pump from a wrecker may be worth the trouble for $20.00. It will likely be better than the one you already have (cleaner too!).
I agree with "jonm61" with regard to Ford PS pumps. They are all problems waiting to happen.
