Bronco II Ford Bronco II
Fuse for "push button" 4 wheel drive...
Old Oct 22, 2005 | 11:38 PM
lil'_bronc's Avatar
lil'_bronc
Well, my 4 wheel drive was working yesterday but, when I pushed the button today, I got nothing. Reset the control module behind driver's seat and still nothing. I am wondering if there's maybe a fuse between the 4 wheel "on/off" switch and the module or transfer case engage motor. Unfortunately, the crappy Hayes manual I have neglected to include any components of the electric 4 wheel engagement systems in the electrical system schematics. I have no owner's manuals nor is the fuse-box cover there, so I'm lost.
Any one know which fuses are in the circuit or can point me in the right direction to trouble-shoot?
Old Oct 23, 2005 | 06:54 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 24, 2005 | 01:20 AM
87 XLT's Avatar
87 XLT
Dont know what you're driving, but if it's an 87 the cruise control & control module are wired to fuse 6. Theres also a fuse link.
Enter the info for your B-2 at autozone.com & you should be able to find an online wiring diagram.
Old Oct 24, 2005 | 11:08 AM
lil'_bronc's Avatar
lil'_bronc
Ah, it is an 89' Bronco XLT. The control module is getting power and will "reset" if you push the reset on the side, but when the "4x4" button on the dash is pushed, nothing happens. This is all of the sudden, because I was running it the other day and it was fine. So, I am wondering if there is a fuse in the circuit between the 4x4 switch and the control module - acutally, I'm not sure the 4x4 button controls the module or if the module is a secondary circuit off of the transfer case motor. This is the wiring diagram I can't find. I would think that the 4x4 button tells the transfer case shift motor to shift into 4-wheel at which point the motor converses with the control module as to how to do that. However, seeing the circuit in a diagram, it is just me guessing. The autozone diagrams are copies of the, incomplete, diagrams in the Hayes manual.
Old Oct 24, 2005 | 12:26 PM
87 XLT's Avatar
87 XLT
Yours might be different, but the only fuse on an 87 is number 6.
This and a fuse link are both wired to the control module.
From the 87 shop manual heres how to self test the control module. Remove the 5 & 8 wire connectors from the control module, turn ignition switch to run Activate the self test switch, a flashing indicator lamp is good a solid lamp is bad.
From reading other posts I believe the most common problem on these are dirty electrical contacts in the shift motor.
cbrd1999
1983 - 2012 Ranger & B-Series
May 30, 2017 04:50 AM
Fuzzy_The_Wuzzy
Aug 1, 2016 03:17 PM
jesseprince94
Jul 7, 2015 10:45 PM
Beeler
31
Dec 27, 2012 10:20 AM
95FordTruck02
1978 - 1996 Big Bronco
May 26, 2011 08:26 PM
