Bronco II Ford Bronco II
Relay location??
Old Oct 22, 2005 | 09:26 PM
traveler2's Avatar
traveler2
Relay location??
Hi guys,
I was wondering if there was a relay that was shared by both the temp gauge and fuel gauge, and if so, where is it located? These two gauges do weird things after the vehicle warms up and I was thinking that it might be a relay on its way out. Thanks for your help.
Old Oct 22, 2005 | 10:13 PM
74 bronco's Avatar
74 bronco
I don't beleive there is a relay for the gauges.
Clint
Old Oct 23, 2005 | 09:26 AM
traveler2's Avatar
traveler2
Thanks for the info Clint. I don't suppose you have any ideas why the gauges would move up and down after it warms up, would you??
Rick
Old Oct 23, 2005 | 10:58 AM
74 bronco's Avatar
74 bronco
I don't know why they do it but they are famous for doing it.
Clint
Old Oct 23, 2005 | 05:45 PM
traveler2's Avatar
traveler2
What do you mean, famous for doing it? Is it common for the gauges to be unstable in a Bronco ll? I have never had one before so I'm not used to this. I really don't recall anyone ever talking about this sort of thing. I just hope that there's an easy and cheap way of solving this problem.
Rick
Old Oct 23, 2005 | 07:04 PM
74 bronco's Avatar
74 bronco
My father has couple of the b2's they have done he is on his third one once we get going we will see if it has the problem.
Old Oct 24, 2005 | 10:14 AM
mrshorty's Avatar
mrshorty
I don't have the correct wiring diagram, but I suspect the dash gauges either share a common power supply or common ground that could cause the behavior you're seeing. Our moderator, Ken00, seems to have access to many wiring diagrams, you might see what he can get you, or get a hold of a good manual and see what you can find.
Old Oct 24, 2005 | 01:25 PM
87 XLT's Avatar
87 XLT
Like mrshorty sez it could be a ground problem. Check the engine to firewall ground strap for a clean tight connection.
Old Oct 24, 2005 | 07:26 PM
Ken00's Avatar
Ken00
My 1989 Ford diagram show they are both powered by fuse 16, a red/yel wire and share a comon ground, the volt, tach & oil also share this ground. The ground location is listed as " in center of LH fender apron near top ".
Old Oct 24, 2005 | 09:30 PM
traveler2's Avatar
traveler2
Thanks for all your help and shared knowledge. I think I'll go out and get a manual and start doing my homework and try to understand this thing. Any suggestions on a good manual that an idiot can understand. Thanks again.
Rick
Old Oct 25, 2005 | 07:21 PM
Ken00's Avatar
Ken00
I like the Ford manuals, you might find one online for your truck.
GeorgeNteri
May 2, 2016 10:42 AM
59Terry
Modular V10 (6.8l)
May 28, 2013 07:40 AM
Airzima
Sep 23, 2012 11:56 AM
Fulthrotl
Jun 11, 2012 07:47 PM
KawiG5
Aug 10, 2004 05:30 PM
