E150 Transmission Problem
Old Oct 22, 2005 | 09:24 AM
mikevv's Avatar
mikevv
I have a 94 E150 with a 351 engine. It has 150k miles on it and runs great. I had the transmission flushed at 120k miles. About once every 200 miles the transmission seems to drop down a gear, the engine races, there is a hard clunk when it shifts back up and then everything goes on as normal. This always happens at light throttle and low load. It will happen with OD on or off. I have taken it to a dealer and there are no codes and no obvious problems.
Any ideas?
Old Oct 22, 2005 | 06:05 PM
Ponyracer's Avatar
Ponyracer
I would suspect the MLP/TR sensor on the drivers side of the trans at the shift lever. It can cause all kinds of trans issues and not set any codes.
Old Oct 24, 2005 | 03:24 PM
mikevv's Avatar
mikevv
Mlps
Jim
Can you tell me a little more about where it is located? I can see where the shift lever goes into the trans on the driver side and there are a lot of connectors and cables in the area. What exactly am I looking for?
Thanks Mike
Old Oct 24, 2005 | 05:08 PM
Ponyracer's Avatar
Ponyracer
I am assuming that you have the E4OD transmission. The pan is a long rectangle with a rear corner cut out like this;
The MLP/TR sensor will be mounted behind the trans shift lever on the drivers side. If the wiring connector plugged into it is a "D" shape then Ford has an update for it and you should update it. Also, when you replace it, put Dielectric grease in the connector to seal out moisture and protect the connection.
Old Oct 31, 2005 | 07:29 AM
mikevv's Avatar
mikevv
So far so good
I replaced the MLPS and drove the Van 250miles this past weekend with no problems. I will need another 200miles to be positive but I am very optimistic that the problem is fixed. Thanks to all for your advice.
Mike
Old Nov 1, 2005 | 12:11 AM
Ponyracer's Avatar
Ponyracer
your welcome, Let us know if there are any more concerns and we will hope this is repaired.
Lucky
15
Jul 12, 2021 11:15 PM
latechbanjo
Jan 17, 2014 11:29 PM
CSneider
1997 - 2003 F150
Nov 4, 2010 02:48 PM
raytasch
Jul 20, 2004 11:13 AM
KMAC
Nov 14, 2003 06:48 PM
