motor swap
Old Oct 22, 2005 | 06:32 AM
irnegl's Avatar
irnegl
Question motor swap
I am considering taking a 300 straight six f-150 and replacing it with a 302 out of an 88 f-150. Does anybody know how difficult of a wiring project this is going to be? I'd like to have an idea before I decide whether or not to do it.
Old Oct 22, 2005 | 06:37 AM
ford390gashog's Avatar
ford390gashog
other than the fact you are going in reverse. you will gain more by keeping the 300 six the 302 is not worth you time.
Old Oct 22, 2005 | 06:48 AM
irnegl's Avatar
irnegl
OK-her's my dilemma. I have a 1988 F-150 4x4 with a non-electronic AOD transmission and manual lockout hubs. Tranny and transfer case mount both have cracked housings. This truck has a good 302 engine. I also have a 1990 F-150 4x4 with electronic AOD transmission and automatic hubs. This truck has a worn out 300 straight 6 with a blown head gasket. This truck also has a better condition body. What would be the best way to combine the two trucks for one good one?
Old Oct 22, 2005 | 07:24 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 22, 2005 | 07:49 AM
Jack01's Avatar
Jack01
put the 302 in the good body truck an mate it up to the better of the two trannys. you will have to change the chip in the 90 F150 to except the 302 and if I got this right the 88 f150 is a efi engine so it should work ok and the only thing that you have to do is bring it up to 90 smog standards. it will fit as the 302 had many trannys from ford behind them. best thing to do is find a 90 in bone yard with a wire harness or graft in the 88s it should be the same Ford did not make to many changes over the years..get a good wire diagram fro both years then have fun
Old Oct 22, 2005 | 08:18 AM
quaddriver's Avatar
quaddriver
Unless someone did some swappin, the tranny in the 90 with the I6 is the E4OD as the AODE was not used yet....
This tranny requires an ECM with PCM options. It can be done but you will need to find a 5.0 ECM that had the E4OD in it.
JP-F150
1997 - 2003 F150
Mar 30, 2012 05:36 AM
79outlawf150
Jun 4, 2010 08:51 AM
crmikef150
Jan 7, 2008 12:03 AM
80`F-150
Nova Scotia
Feb 15, 2005 05:01 PM
canadianfordman
Car/truck Buying Advice
Aug 5, 2002 03:48 PM
