How do I replace a headlight?
Old Oct 21, 2005 | 03:54 PM
johnymac60's Avatar
johnymac60
I just got my first truck. Its a 1996 F150 and has a cracked headlight. I got a nice replacement off ebay, but i cant figure out how to take off the trim without breaking it. How do I replace this headlight?
TIA
John
Old Oct 21, 2005 | 04:40 PM
subford's Avatar
subford
More than likely you will only have to do 1 &2.
But the nuts are not the easiest to get to.
Removal and Installation
1. Remove two screws and two nuts retaining headlamp door (13064).
2. Pull headlamp door from vehicle. Remove three bulbs and sockets.
3. Disconnect engine control sensor wiring (12A581) from headlamp bulb (13007).
4. Remove two retainers attaching upper two attachments of headlamp (13008).
5. Turn horizontal headlamp adjusting screw (13032) completely out of the adjusting nut.
6. Pull headlamp from vehicle.
For installation, follow removal procedures in reverse order. Tighten screws to 1.4-2.3 N-m (13-20 lb-in). Tighten nuts to 4-7 N-m (36-61 lb-in). Check headlamp aim.
Old Oct 21, 2005 | 04:58 PM
johnymac60's Avatar
johnymac60
I guess its the Headlamp Door that I'm having a problem with. Is that the trim piece that surrounds the whole light cluster? How do I actually get to the nuts? Where are they?
Thanks,
John
Old Oct 21, 2005 | 05:02 PM
subford's Avatar
subford
I posted a diagram in my other post.
Old Oct 21, 2005 | 05:11 PM
subford's Avatar
subford
Thanks,
John
Is that the trim piece that surrounds the whole light cluster? YES
How do I actually get to the nuts? Not the easy thing to do but I used a 1/4" drive ratchet hooking my fingernail over the washer to keep it in the socket.
Where are they? They are #9 (The NUTS) and #2 (The Screws)
johnymac60's Avatar
johnymac60
Ok, so the two number 9 nuts. I see.
Cheers,
John
atomicjoe23
28
Jul 12, 2015 06:52 PM
ShawnQ
Nov 12, 2014 08:54 AM
97biostroke
1978 - 1996 Big Bronco
Apr 5, 2011 07:24 PM
RobBroekhuis
Electrical Systems/Wiring
May 18, 2005 04:49 PM
stephenf
Feb 13, 2005 10:24 PM
