headlight switch repalcement
Old Feb 13, 2005 | 03:11 PM
stephenf's Avatar
stephenf
how do you replace a bad headlight switch on a 1968 ford
Old Feb 13, 2005 | 03:55 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
…..See you on the boards.
Old Feb 13, 2005 | 10:24 PM
RICHMC54's Avatar
RICHMC54
Behind the dash, on top of the switch towards the back, there is a little button. When you push it in and pull on the ****, it will come out. looking at where the **** hole you will see 2 indentations. I use needle nose pliers to unscrew this.the switch will pull out the back. unplug the the wires (1unit) replace the switch. I did thid yesterday. hope this helps
