Sponsored by: Real Truck
spray in bed liners
Old Oct 21, 2005 | 08:03 PM
BobbyDiesel71's Avatar
BobbyDiesel71
Originally Posted by Kepler4
I removed the plastic and the Line-X shop put metal tape over and under the holes and shot over the tape and under the rails. It's held up just fine sine May.
They also removed the bed bolts and tailgate access cover screws. They shot over the two oval rubber grommets on the front of the bed. Looking back, I would probably ask them to remove those.
What are those two grommets for?
I would imagine drainage
I had the dealership spray LINE-X for $250, they told me the same thing about the bed rail caps, I wanted to spray the bed rails and a bit under them, but they were against it.
Old Oct 21, 2005 | 08:56 PM
bandaman's Avatar
bandaman
Just had Line-X sprayed in the bed of my 06 yesterday
It looks great!!!!!! Very "factory" looking and professional. I had Rhino lining in my last truck that I had for 5 years. Although I liked it, the installation was not near as neat and clean as this line-x. The Rhino had more inconsistencies in the looks, depth, and had runs and nasty looking edges around the tail gate area. I was also able to gouge it with a shovel pretty easy
My Line-X guy removed all the bed bolts, the tie down hooks, the tail gate bolts, and sprayed the tail gate access panel separate in case I ever need to get in there. He went up over the top of the front rail, and I had him go a couple inches down the back of the bed (below tailgate) and to 1/8" of the edge of the bottom of the gate. All edges are near perfect, no runs, drips, or messes. He also sprayed over the rubber grommets in the front of the bed as he has had no one from Ford give him an explanation for why these are there. He has sprayed over all of them and so far has had no one need to remove them for anything.
Rhino I had color matched and was over $700 5 yrs ago. Got the Line-X in black (in my black truck) for $470 Also had my truxedo lo-pro tonneau installed at the same time. 3hrs total and I was out of there.
I'll add some pics to my gallery in a few days.
Old Oct 21, 2005 | 10:15 PM
2005V10F250CC's Avatar
2005V10F250CC
Here's a photo of the line-x install had done this morning. I think it looks good. They removed the bed bolts, tailgate access cover, and tie downs. They sprayed over the rubber grommets in front. There are a couple of additional photos in my gallery with the toolbox back on the truck after the install.
Old Oct 21, 2005 | 10:25 PM
4S FED's Avatar
4S FED
Hey, that looks great! Goin' to get my truck done after it gets out of the body shop...
Old Oct 21, 2005 | 10:46 PM
olfordsnstone's Avatar
olfordsnstone
Got her done! Looks great. They did remove all of the hardware and rear panel done seperately. My digital camera is not available right now but mine looks just like 2005v10's photo. I'm sold on linex. Great job and guaranteed for as long as I own the vehicle for chips or whatever.
Old Oct 21, 2005 | 10:51 PM
Kep4's Avatar
Kep4
Jäger
I guess the grommets are for slide-in camper applications? Maybe that question is worth a seperate post.
I would like to run the air-compressor power lines and air hose through them. I'm going to mount my compressor in a cross-bed toolbox. I could probably just slice the grommet and run the lines through.
