I've just redone my door panels and looking for a way to replace the original wire clips. Some of the plastic on the back of the panel is broken and I'll have to epoxy new clips in. What I'm looking for is a plastic clip that will work. Any ideas????
I would suggest using the plastic type found in the parts stores "Help" section, just match up the length to one of your original wire type ones, the plastic seems to hold better for me, and they are cheaper than buying originals, you should be able to epoxy them on as well. Good Luck!! Rick
