scmt error code p0603
Old Oct 20, 2005 | 10:07 PM
gotama's Avatar
gotama
central internal control mod KAMM....whats this??...truck runs perfectly btw
thanks in advance
Old Oct 20, 2005 | 10:10 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Most common code to show up with a tuner. It will also show up if you have unplugged the batteries. Stands for KEEP ALIVE MEMORY. No big deal, mine shows it all the time. Clear the code with the SCMT and it should go away. It will not hurt anything though.
Old Oct 21, 2005 | 08:28 AM
CAT_man_963's Avatar
CAT_man_963
Yep - that's it!! I think it pops up ever time you use the tuner too - so if you use the tuner to erase the code, then it will set the code again!! (At least that's what mine did back when I had my SCMT... Forget about that code and drive!!
Old Oct 21, 2005 | 11:13 PM
wycowboy's Avatar
wycowboy
mine does the same thing!! each time I plug in it shows up.
