351 Redline
Old Oct 25, 2005 | 09:22 AM
Kemicalburns's Avatar
Kemicalburns
69 cougar would have been a cleveland motor not a windsor. but yes that motor would rev that hi but was built for it as well.
now my 95 5.8 will touch 5500 no problem but it has a roller cam which helps alot as well.
Old Oct 25, 2005 | 12:17 PM
Spaznaut's Avatar
Spaznaut
I pulled a 351w 2bl from a '69 cougar. But not sure if it was original. We used '69 parts for the heads though. It had thrown a rod but fixed it and put it in my '87 mustang. Was a good motor.
Old Oct 25, 2005 | 01:13 PM
lmadore's Avatar
lmadore
With that engine tranny combo, you won't get much torque or usable HP past 4000K.
My truck (86 F-150 5.0 EFI) with the NP 435 4-SPD does about 100 MPH at 4K.
Much higher than 4K and the lifters come dangerously close to floating with the stock valvetrain and cam. (Approx 235K on the motor with no rebuild - running sythetic oil).
Old Oct 25, 2005 | 09:20 PM
MustangGT221's Avatar
MustangGT221
Yup, the newer 351 can go to 5500. I think with the hydraulic cam, the actual cam specs were a little better too.
My 95 truck 302 shut the injectors off at 5500. I've had a 95 300 I-6 at 5500 rpm too (thats a low rpm engine!).
Although I've never ran a mustang 5.0 to 6200, i believe that is what they run to. The bottom end should be good to 6200, and I believe the injectors shut off at that RPM. I could be wrong but I'm 95% sure. A stock bottom end 302 with ARP rod bolts can run to 6500 if that means anything to ya.
That older 351 is definitely in at 5000 regardless of age, runs out of air around 4500 by design.
Old Oct 25, 2005 | 09:38 PM
sierraben's Avatar
sierraben
The first year for the 351C was 1970.
The engine code for my 69 XR-7 was "M" (351w-4V)
http://en.wikipedia.org/wiki/Ford_335_engine
Old Oct 26, 2005 | 09:33 AM
Kemicalburns
thanks for that link Sierraben. good info.
Old Oct 26, 2005 | 11:11 AM
garsten's Avatar
garsten
...the mustang 302 is the same bottom end but since it's top end can flow more air it gets a higher redline.
i believe the crank main journals, rod journals and rod lengths are different between the 302 and the 351W...making the bottom ends quite different. the longer stroke of the 351W also relates to lower rpm's on stock engines.
mustang 5.0L computers quit @ 6250 no matter what the tach says...from what i've read factory 5.0 tachs are not the most accurate. cheers, garsten
Old Oct 26, 2005 | 01:07 PM
MustangGT221
I was refering to a mustang HO302 vs the truck 302...not a mustang HO302 vs 351w
You're correct in what you've said though...a 302/351 are pretty different.
The stock truck tachs arn't all that accurate either, they can be off a couple hundred RPM. I was getting slightly different numbers between the dyno RPM monitor and my dash tach.
Old Oct 26, 2005 | 02:47 PM
'78 Custom's Avatar
'78 Custom
On the tach thing, i was sort of disappointed on it not having a factory tach, but seeing what you guys said about them, im glad its got an aftermarket. Thank god its a smaller one with no dummy light i hate those things
Old Oct 26, 2005 | 02:53 PM
sierraben's Avatar
sierraben
What's nice about the 289 is that it had a slower piston speed than the 302 or the 351w.
It was a screamer.
But than again, all of the small blocks were screamers.
topscrt
Modular V10 (6.8l)
Sep 8, 2013 02:03 PM
IcemanV8
Dec 6, 2007 09:15 AM
chulsey12
May 30, 2007 06:43 PM
matthew35
Oct 17, 2006 12:07 PM
rankhankyellow
15
Mar 10, 2004 10:53 AM
