Rearend Gears
Old Oct 20, 2005 | 08:22 PM
F15090300's Avatar
F15090300
Rearend Gears
1990 F150 4x4, 300 I-6, E4OD
I currently have 32x11.50 tires. I'm just wondering what gears I should throw in my rearend (a Ford 9-inch) so I can cruise at lower revs at 65.
Thanks for the help.
Old Oct 20, 2005 | 08:44 PM
subford's Avatar
subford
What gears do you have now?
Old Oct 20, 2005 | 08:51 PM
F15090300's Avatar
F15090300
Pshew...uh...
*shakes head in shame*
Possible 3:10's
Old Oct 20, 2005 | 08:58 PM
subford's Avatar
subford
Pshew...uh...
Possible 3:10's
If you have 3.10:1 you would have a low rpm already.
Old Oct 20, 2005 | 09:06 PM
F15090300's Avatar
F15090300
maybe it's 3:55's or 4:10's
I always forget which gears (taller or shorter) give you lower gearing.
Old Oct 20, 2005 | 09:12 PM
pmasley's Avatar
pmasley
I would say that he has 3.55. A change to 3.73 would improve drivability with the 32's. 4.10's would kill the top end, but make it a monster getting out of the hole. Fuel mileage would also suffer with the 4.10's.
Old Oct 20, 2005 | 09:54 PM
andym's Avatar
andym
Ford never made a 3.10 ratio in either the 8.8" or the 9" axle that I know of.
Since a 9" wouldn't have been factory issue in your 1990 truck, are you sure that's even what axle you have?
If better gas mileage is what you want, consider that the cost of changing out both the front and rear axle gears is going to be close to $1200. How much gas does that buy you? Remember you're driving a 5000 lb truck around regardless of what gears are in it.
Old Oct 22, 2005 | 08:30 AM
96_4wdr's Avatar
96_4wdr
go to 35" narrower tires and rims on 16 or 17 rims, gives about 10% drop in cruise rpm, less tire wind and road rolling resistance=better fuel mileage. save the wide 32" for weekend boy toy playing in the mud. run the tires at near max pressure.
far cheaper than changing 2 r/P sets and more adaptable.
Old Oct 22, 2005 | 09:47 AM
F15090300's Avatar
F15090300
I'll get skinny 32's or 31's before next winter. I'd probably need a lift for 35's, unless I got really skinny ones, otherwise, they'd still fit under the wheelwells, but they'd rub the frame like crazy. I'm getting a little frame rub from the wide 32's.
Thanks for the gear help guys. I probably wont throw in gears, I was just wondering what gears would help me cruise better.
Old Oct 22, 2005 | 06:33 PM
sierraben's Avatar
sierraben
Actually, I think Ford did make a 3.10 ratio.
I had one in an old 65 Ford Country Squire Wagon.
