Sponsored by: Auxito
Heat/Cold control knob
Old Oct 20, 2005 | 07:53 PM
GA_DAWG's Avatar
GA_DAWG
Heat/Cold control ****
anyone ever had a problem with your heat/cold ****. I replaced the sensor on the back of my ****, and now the only thing that will work is the defrost, even if it I select floor, or vent. Any suggestions
Old Oct 20, 2005 | 11:27 PM
PaulC's Avatar
PaulC
Pull the **** cluster again and look for a loose or cracked vacuum hose running to the cluster. The HVAC system is intentionally designed to default to the defrost mode in the event of a vacuum leak in the system.
Old Oct 21, 2005 | 06:24 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
