Sponsored by: Auxito
Electrical Whine
Old Oct 11, 2005 | 04:31 PM
clueless's Avatar
clueless
Electrical Whine
My 2001 F150 4X4 Supercrew (100K miles) has developed an electrical whine that can be heard through the stereo in conjunction with pressing on the throttle. It does not matter if the stereo is on or not the sound can still be heard.
Any ideas what this could be?
Thanks in advance!
Gerald
Old Oct 11, 2005 | 09:16 PM
Racerguy's Avatar
Racerguy
Usually that is caused by a bad alternator.
I'd start by checking all the grounds near the battery though. If they are all good then I would unplug the connector on the alternator and see what happens.
Old Oct 12, 2005 | 07:04 AM
clueless's Avatar
clueless
Thanks Dave. I checked the grounds around the battery, cleaned and tightened them up, no help. I as afraid it might be the alternator. I will test it out this afternoon.
Gerald
Old Oct 12, 2005 | 08:22 AM
Racerguy's Avatar
Racerguy
Please let us know what you find.
Old Oct 12, 2005 | 03:48 PM
clueless's Avatar
clueless
I have checked all the grounds, disconnected the alternator, disconnected the battery and the whine is still there. I also pulled the fuse to the radio and the whine is still there. So I think I as wrong when I said it was coming over the stereo. I don't know where it is coming from now. It is not that bad and most people would never notice it but I am kind of ****.
Guess I am going to have to take it into the shop.
Old Oct 19, 2005 | 11:28 PM
rhino_160's Avatar
rhino_160
do you have aftermarket subs or anything like that installed?
if you do and you have RCA cables and a power wire running, you need to make sure that your RCAs are ran on one side and the power is running on the other. they do not need to be together, this sometimes causes the noise that you hear more when you press the gas. let us know what you find, -Rhino-
Old Oct 20, 2005 | 10:14 AM
lancekilgore's Avatar
lancekilgore
check the ground on the stereo, or add a ground.
Lance
Old Oct 21, 2005 | 08:00 AM
dkoenig's Avatar
dkoenig
This might sound funny, but I thought I had an electrical whine, and it ended up being the PCV valve. Make sure you have a clean and "good" PCV valve.
Cheap, won't hurt to change, and might fix it.
gharmon
1997 - 2003 F150
May 15, 2012 10:35 PM
gharmon
1997 - 2003 F150
Feb 28, 2012 05:54 PM
gharmon
Oct 10, 2010 06:57 PM
gharmon
1983 - 2012 Ranger & B-Series
Jan 21, 2002 11:00 PM
Gerald Ash
Apr 22, 2000 10:58 AM
