EGR problem
Old Oct 20, 2005 | 05:08 PM
furz4's Avatar
furz4
EGR problem
I recently replaced the EGR valve on my 91 F250 351. I had the motor running with the new valve installed before I connected the tube and I noticed it was drawing in air even at idle. I thought EGR was supposed to be closed at idle, or is it normal to have a small amount of draw all the time? It does not cause the check engine light to light but idle is a little rough. Perhaps I just got a new valve that was defective. Anybody else ever notice this.
Old Oct 23, 2005 | 01:10 AM
griffith04's Avatar
griffith04
There shouldn't be any air passing through at idle. Make sure there is no vacuum at the line to the valve. I have gotten new bad parts before. Take the valve off and try to blow through it, it should not let air go by.
