Sponsored by: Auxito
Another Torsion Bar Question
Old Oct 20, 2005 | 04:49 PM
punisherfx4's Avatar
punisherfx4
Question Another Torsion Bar Question
I have been reading all the torsion bar threads, but I haven't seen this question asked:
I'm going to use the re-indexed torsion bar cams and get a 2" lift in the front. My question is do I need 2" longer shocks. I've seen everyone talking cranking there bars, but haven't seen anyone mention shocks. Any thoughts?
Old Oct 20, 2005 | 08:27 PM
steve(ill)'s Avatar
steve(ill)
the standard adjustment screws allow a lift up to about 2 inches. the standard shocks will work with that lift. i dont know about the reindex you are talking about, but if the lift is limited to 2 inches, you should be o.k.
Old Oct 21, 2005 | 01:53 AM
punisherfx4
Thanks, that's what I needed to know!
The re-indexed cams keep you from having to screw the adjustment bolts all the way in which puts all of the stress on the tip of that bolt.
Old Oct 22, 2005 | 06:00 PM
V10F250's Avatar
V10F250
Where did you get the re-index cams, and how much were they?
Old Oct 23, 2005 | 07:56 PM
punisherfx4
Ebay
$155 for set w/ 2" add-a-leafs
$75 w/o
