Clunk in rear: TSB??
Old Oct 20, 2005 | 04:41 PM
AllenB's Avatar
AllenB
I've searched all of the posts about the clunk coming from the rear end while taking off from a dead stop. I've got the same problem. I didn't ever find a "fix" for this or a difinitive solution. Is there a TSB on this and are most dealers aware of the problem? I'm going to take mine in soon but want to know really what the problem is.
Thanks all!
Allen
Old Oct 20, 2005 | 04:51 PM
mhoneyf150's Avatar
mhoneyf150
I took my truck in on Monday for this problem and they seem to have fixed the issue. Clunking noise is gone and seems smoother now going thru the gears. Not sure what the TSB number is but my dealer said there was a TSB for it and the TSB is what they went by to fix it. Had something to do with adjusting and lubing the yoke.
Hopes this helps. Left paperwork at home. If I remember to bring to office I will tell what is noted.
Old Oct 21, 2005 | 10:22 AM
Jozzie's Avatar
Jozzie
AllenB,
Does it 'Clunk' when going 20 MPH, then down shifting while going up an incline?
Mine is doing that, as well as the symptom you mentioned.
Old Oct 21, 2005 | 11:24 AM
Steve91's Avatar
Steve91
They "fixed" mine with the lube, but it is back, worse than ever, at about 10,000 miles later. I'm beginning to really dislike this truck.
Old Oct 21, 2005 | 11:53 AM
KevinM's Avatar
KevinM
Here ya go!
<TABLE class=searchBorder width="95%" align=center><TBODY><TR><TD class=nav width="50%">Make: </TD><TD class=navBlue>FORD </TD></TR><TR><TD class=nav>Model: </TD><TD class=navBlue>F150 </TD></TR><TR><TD class=nav>Year: </TD><TD class=navBlue>2004 </TD></TR><TR><TD class=nav>Type: </TD><TD class=navBlue>TRUCK </TD></TR><TR><TD class=nav>Service Bulletin Number: </TD><TD class=navBlue>04266 </TD></TR><TR><TD class=nav>NHTSA Item Number: </TD><TD class=navBlue>10014275 </TD></TR><TR><TD class=nav>Summary Description: </TD><TD class=contentText> </TD></TR><TR><TD class=contentText colSpan=2>A DRIVELINE CLUNK OR BUMP WHEN STARTING FROM A STOP. *TT </TD></TR></TBODY></TABLE>
Old Oct 21, 2005 | 08:25 PM
WhëëlMå1's Avatar
WhëëlMå1
It is due to an improper driveline angle. There is a shim kit, as well as lube for the slip yoke that is designed for this. I also have this problem. Drop me a PM if you want to talk about it.
sbraatz
Escape & Escape Hybrid
Feb 4, 2017 07:00 AM
Bigtbassman
Dec 26, 2016 06:49 PM
powerstroker04
Oct 4, 2015 11:00 PM
slow3v
Oct 5, 2011 07:38 PM
Beerstalker
Sep 17, 2008 01:24 AM
