Will not start
Old Oct 19, 2005 | 09:42 PM
MarkHB's Avatar
MarkHB
Will not start
I jumped into my truck (F350 DRW)tonightand it would not start.
Drove it home this afternoon fine.
Engine turns over fine so batteries are not flat,
Normal lights on dash,
Acting like there is no spark like on a gas engine ceptin of course it is a diesel.
Head scratching here
Any ideas?
Thanks
Mark
Old Oct 20, 2005 | 10:37 AM
kw5413's Avatar
kw5413
It will be important to know some history before anyone can really offer up any assistance as many things can cause a no-start condition.
Engine build date would really help.
Prior service history....etc.
Old Oct 20, 2005 | 10:39 AM
amish77's Avatar
amish77
well............
how cold was it at night? The glow plugs are necessary when it gets overly cold, and the diesel can gel up too. As of right now I'm thinking glow plugs.
Old Oct 20, 2005 | 10:51 AM
pachangalpina's Avatar
pachangalpina
Mine is torn apart at the dealer right now. Will start cold but not after it has been running for a period of time. I have an '05 and this problem started at 36,450 miles. Go figure
Old Oct 21, 2005 | 09:28 AM
JimRietz's Avatar
JimRietz
Acting like there is no spark like on a gas engine ceptin of course it is a diesel...
My '05 quit running while driving... lucky you! Anyway, same symptoms... after 2 weeks in the shop (31k miles, btw), they found an O-ring had failed on a splitter tube for the high pressure oil system. This system feeds the injectors and is necessary for them to operate. Of course, before they found the O-ring, they did fumble around a lot replacing things (EGR, 1 injector, oil, etc.) due to all the fault codes they found - none of which were for this problem though. Sometimes the computers & codes don't work...
Jim
Old Oct 21, 2005 | 09:55 AM
kw5413's Avatar
kw5413
Like Jim said:
2005 High Pressure Oil System Leak:
Some 2005 SuperDuties and Excursions built after 1-10-05 may experience symptoms related to high pressure oil system leakage, most commonly a hard/no start when the engine is warm. If diagnosis indicates a leak at the HP oil pump, inspect the pump quick connect fitting. If the leak is at the fitting o-ring, replace the fitting with P/N W301727. Broadcast Message 4320.
Or:
2005 Trucks, Crank/No Start, Hard Start, Runs Runs Rough at Idle:
Pickups and vans built before 4-15-05 and Excursions built between 1-10 and 4-15-05 may exhibit hard or no start conditions with a low ICP signal, or a rough idle with a high ICP signal. This may be due to a damaged high pressure oil pump and/or IPR valve. The IPR valve should be removed (mounted on HPP cover under the turbo) and inspected for a damaged inlet screen or debris on over half the screen. If either condition is present, the IPR (5C3Z-9C968-CA) and the high pressure oil pump (5C3Z-9A543-AA) should be replaced, along with the oil and oil filter. If neither condition is present, continue with normal diagnosis. If a rough idle is present after replacing the above parts, injector damage may have occured.
TSB 50-12-3.
Good luck.
Old Oct 21, 2005 | 04:59 PM
rrrrick's Avatar
rrrrick
Soooo What did the dealer tell you.. have you got it to the shop yet?
My Crank no start problem was the oil pressure regulator.
Old Oct 21, 2005 | 08:22 PM
MarkHB's Avatar
MarkHB
I should have stated it is an 06 model. 2180 miles on the clock, have not even got the plates yet.
I had it towed to the dealer yesterday morning. They said low oil pressure is stopping it from starting.
The gave me a courtesy vehicle to drive while it is in the shop.
Received a call from the dealer this afternoon and they still have not found the problem. Needed a new tool to dive into the diesel further and that will not arrive until Tuesday.
I think I will be paying them a visit tomorrow and talk to the mechanic himself.
I will keep you posted.
Thanks for your help.
Mark
Old Oct 21, 2005 | 08:48 PM
JimRietz's Avatar
JimRietz
...Needed a new tool to dive into the diesel further and that will not arrive until Tuesday.
That's a good excuse! I know if it was me, I'd be looking for a Ford "truck" dealer - not a car dealer who sells trucks. I'm taking mine in to a truck dealer next week to have the motor looked at (it smokes and runs horrible until warm).
I was going to take it to the dealer where I bought it, but the only diesel mechanic cut his finger off and is out for a few weeks. The second closest dealer's #1 diesel guy quit and started his own business - I think they are left with only their #2 guy... Both of these dealers are car dealers who sell trucks. The truck dealership sells only trucks... and they have more than one diesel guy and a larger inventory of parts.
BTW, when mine died a few months ago, I had to talk (threaten?) to the service manager and dealership manager to get things going... like waiting for parts...
Good luck!
Jim
Old Oct 23, 2005 | 12:42 AM
usroute66's Avatar
usroute66
Mark, I hear Sunrise Ford out in San Bernardino has a good diesel guy. He builds his own engines for racing...not sure of his name, but if U mention about the engine building, they should know who it is. It is a ways to drive (I live in Culver City myself) but if push comes to shove, U might want to call them. Good luck!
Old Oct 23, 2005 | 07:59 AM
MarkHB's Avatar
MarkHB
I will see what happens with the local dealer. It's not like I can drive anywhere else for now. I am also flying to Houston this morning for a week.
Thanks for the info though. I will keep y'all posted on what happens,
Mark
Old Oct 24, 2005 | 10:28 AM
rrrrick's Avatar
rrrrick
I had lots of problems with my local car dealership's service department. I switched to a local medium duty Ford dealer ( Heavy truck mechanics) and have been happy since
Old Nov 11, 2005 | 08:28 PM
MarkHB's Avatar
MarkHB
Here is an update the problems of not being able to start.
As of yesterday the truck has been at the dealer for 3 weeks and is still not operable. They had to wait for some tooling, ordered the new parts in the oil pump somewhere and it still will not start.
Getting close to the CA lemon law.
Mark
Old Nov 12, 2005 | 12:56 AM
harleyfordman's Avatar
harleyfordman
I had a similar problem with warm starting on my 05
The dealer installed a new fuel pump...so far so good
Old Nov 19, 2005 | 03:33 PM
MarkHB's Avatar
MarkHB
I finally got my truck back after 4+ weeks in the shop.
Here is as written on the repair sheet.
Vehicle cranks but won't start.
EEC Test. P1211. P1212. KOEO.P1211 Injector Test Pass. Fuel Pressure 71 PSI. Check injection pump per SSM18884 No Problem found. ICP 60PSI. Block Right Head. ICP. 60PSI Block Right Head ICP 3200PSI Removed and installed Oil Rails and injectors for inspection. Unable to see source of leak visually. Installed injectors. Replaced left injector rail. Restart OK. Clear Codes. Road tested P1000.
Just over 4 weeks to fix it. Unbelievable.
Mark
