Finally... first "timed" runs...
Old Oct 20, 2005 | 11:49 PM
  #31
gtex's Avatar
gtex
Originally Posted by fordeverpower
i got 5200lbs in my f150 4x4 with me in it. I cost myself 3 tenths alone.
See what I mean. Here's a 1/2 ton 4x4 at 5200lbs..
I smell tuna.
Old Oct 21, 2005 | 10:56 AM
  #32
fordraceboy's Avatar
fordraceboy
run an aluminum intake and wheels, remove everything that isn't needed for speed. tailgate, bumpers, passenger seat, cut and grind all bolts and casting flash from axles and frame and motor, tranny, and t-case housings. gun drill the axles, run 2.5 inch thick wall drivelines-they weigh 20% less than 3" ones.. only run single shocks- no dual set-ups, shocks are heavy! run a quart low in the engine with a full synthetic oil, and cut your tranny and diff capacity by 25%.. by keeping your fluids low you cut a bit of weight but more importantly you reduce parasitic oil drag. drop your fan belts and gain 5% power across the board. one more little trick.. only one gas tank in the cab- drain it completely and dump in 5 gallons of 130 octane in- it won't idle for nothing but you can crank the timing another few degrees and turn an extra 7-800 rpm's.. I'll c if i can find the slip and post it for you.. i always kept them in the glovebox of that truck so maybe they ended up in a box when she cleaned me, i mean it, out..
Old Oct 21, 2005 | 10:58 AM
  #33
fordraceboy
i almost didn't notice that last comment. F150 4x4 -5200 w- a driver... subtract 200 for a driver and you only gotta drop 360 lbs.... not a challenge with bumpers and tailgate alone... remember, there is no difference in running gear from 150 to 250 in the front end, just a 9 in ch versus a dana 60 in the back.. 150 front suspension with coils, track bar, and radius arms outweigh a pair of leaf springs by almost 30 lbs too...
Old Oct 21, 2005 | 11:08 AM
  #34
fordeverpower's Avatar
fordeverpower
my truck probaly weighs about 4900 driverless, I had a steel brushguard on at one time and an alum intake now, maybe even 4800 or 4850 now.
That post was hilarious ****!
Old Oct 21, 2005 | 06:53 PM
  #35
parkerusmc's Avatar
parkerusmc
Ya'll are all funnier than heck. I'm having fun just reading this post, hope you guys keep it up!
Old Oct 21, 2005 | 06:58 PM
  #36
fordraceboy
i'm glad you liked it! i do what i can with that which is set before me... lol yeah if you dump that brushguard and intake your down an easy 125-150 pounds... a cast iron intake weighs 98lbs versus only 18 for an edelbrock performer rpm.... there truelly isn't much weight difference when it comes right down to it with these old fords, they are built so heavy duty in two wheel drive form that they rival the weights of a four wheel drive... maybe that beer went bad and that was the tuna smell...
Old Oct 21, 2005 | 06:59 PM
  #37
fordraceboy
If this is all it takes for us to keep our servicemen happy then you guys are in for alot of laughs with this website!!!!!!
Old Oct 22, 2005 | 04:44 PM
  #38
polcat's Avatar
polcat
well my old truck weights in around 3600lbs with me in it. If I can get it to hook up my 418 fe stroker should put me in the 12's. IF I could ever get the machine shops to get moving on finishing the balancing of it!!!
Brack1
2004 - 2008 F150
Feb 10, 2011 03:55 PM
straightaxle
Modular V10 (6.8l)
Dec 10, 2009 01:57 PM
02GrayPowerStroke
Feb 6, 2008 05:30 PM
CentralCoaster
2004 - 2008 F150
Oct 18, 2005 10:45 AM
thumpmaster
2004 - 2008 F150
32
Mar 25, 2005 08:20 PM
