oil pressure
Old Oct 19, 2005 | 04:03 PM
robbiecox6's Avatar
robbiecox6
Talking oil pressure
I have a 2001 Ranger XLT 3.0 V-6 flex-fuel, every now an then when i let off the gas the oil pressure gauge goes crazy, get back on the gas its fine. Whats wrong with it?
Old Oct 19, 2005 | 06:35 PM
sjwoody's Avatar
sjwoody
I can't answer for the 2001 models, but the older Rangers (and other Ford models) use a simple switch. When the switch is made (at greater than 7psi), a constant voltage goes to the gauge, causing it to move from zero to some mid-range point. It uses a resistor to limit the voltage, which keeps the gauge from pegging at the top end. In other words, it's basically an idiot light circuit, but it displays as a gauge, not a light.
If you have a pressure sensor (vs. a pressure switch) all the above doesn't apply. I would look at replacing the sensor to start with.
Old Oct 20, 2005 | 04:26 AM
PW01's Avatar
PW01
Sending unit is bad, it happened to my 01 4.0.
Old Oct 20, 2005 | 05:39 AM
Bob Ayers's Avatar
Bob Ayers
I agree, it's a bad oil pressure sendijng unit (switch). It's located behind the head on the passenger's side.
Old Oct 20, 2005 | 08:07 AM
oldgoat49's Avatar
oldgoat49
I had to replace the oil pressure sender on my 99 Mazda B3000 because it wouldn't show pressure for about a minute. The dealer said that they had a different one now. I would be a little concerned that it is going up and down though. The sender would be the first thing I would do and be sure the connection is good.
EPTow
Mar 25, 2013 09:45 PM
melissa2433
1997 - 2003 F150
Dec 15, 2012 08:54 AM
bobbyt89
Nov 3, 2010 12:50 AM
Lawman7346
May 21, 2010 09:58 AM
Greywolf
16
Mar 16, 2006 10:36 AM
