In my quest for a better MPG work truck I'm building a 74 F-350 , at this point I can do anything I want for a drivetrain. What I need is a couple of people with identical trucks but 1 auto and 1 standard that know what they are getting for mileage. Preferably someone who drives moderatly. My present setup is 390 4v with c-6 and 3.55 rears. I don't thinkit will matter what the 2 test vehicles are I'm just looking for the difference in mileage as a percentage.
By the way sofar I am ecstatic with the new truck without even tuning it up yet and the tranny slipping a bit it got 10 mpg on the second tank. that's already a 2 mpg jump from my present work truck. That has already knocked $100 a month off my Gas bill.
I have a '73 and '78 F100s both with sixes. '73 has a C4 and the '78 has a 3.03 3 speed. The '78 seems to get a little better mileage, not real signicant but this might be because the engine is in a little better shape and not cause of the manual tranny. I would stay with automatic, if anything get an overdrive automatic like a built AOD. Manuals usually last longer but it can sure get tiresome shifting especially with these old mechanical clutches.
I don't mind shifting at all, I actually like it better than an automatic. The reason I'm asking is because the c-6 I have now is going to need an overhaul, price wise I can probably swap to a stick for the same money although not as easy. but if it would increase mpg it would push me in that direction. because the automatic is never really connected I would think the same vehicle would do better with the standard. If it's significant I would go that way.
Oh and Million, nice post, but it really isn't related to my question. I intend to do everything I can to increase the mileage, this is just one step.
Given the same rear end ratio the standard is capable of higher mileage if driven easily because the torque converter has some slippage and a C-6 takes a lot of HP to turn. Auto's usually have a slightly lower (numerical) gear ration to compensate for this.
ya that's my theory too, I just wanted to know how much. to see if it's worth the changeover. If it was good for a couple of mpg's it would be worth the change.
Ive been told and I read on here that there is a difference of 60rrhp between the C6 and the NP435 4spd manual, the 4psd having more. Id assume mileage increase would be in the 1-4 mpg range.
I've seen guys run 390s with autos an standards, and with either one they don't see much over 10 MPG. The cost of overhauling a C6 isn't cheap, and you could get a NP435 out of a junk yard, put new seals and everything like that, install it, and still probabaly come out cheaper than overhualing the C6 and maybe getting 1 (or 2 at best) mpgs better.
Thanks...My point is:there are so many things that alter fuel economy even a little bit that it is very difficult to be specific about what it will be or be changed to.
Oh I know everything is a guess until you actually do it, the point is I don't need this truck, so I can spend time making it right, or at-least my best guess at what's right. I also have the tools and knowledge to make it anything I want to, so I'm just feeling everyone out and getting opinions. Right now I'm in semi-retired mode, I've decided only to do things I enjoy from now on, and one of those things is reverting back to the Old vehicles I grew up with. I was actually working on my 46 pickup project when I decided that a better work truck would save me a bit of cash so I switched gears and bought the F-350. The way I figure it if I can gain a mpg here and there I may be able to get this thing up to 12 or better and that would be a tremendous improvement over the 8 I'm getting with the van. Right now my gas bill is between 4 and 6 hundred a month. Even at the 10 mpg the 74 is getting now it's going to pay for itself in a year or so. And I get to drive a nice vintage truck.
Don't forget to ask about the terrain when you get a reply. Not even semi accurate mpg comparisons can be made for hills vs flatland.
You probably aren't going to get a perfect comparison for this, but it will be at least more accurate than less accurate when similar terrain is observed.
This is a perfect case for the 2v vs 4v for fuel economy then.
Without the back 2 bbls kicking in,the 4v should get better mileage
I do agree with that, the problem being control of the right foot .
The other thing I've been contemplating is a hydraulic drive axle for the front. There isn't too many times I need 4wd, but it does happen. And I'll have the hydraulic system for a dump bed anyway. And I could build the entire unit without disabling the truck, then just swap it in. that would probably be the last project.
Ditto. And yes, there are so many variables that effect mileage but I have yet to see an auto with a non-lockup converter get better mileage than a comparable truck with a manual. I know it's a completely different truck than you're building but Pro's truck went from 4mpg to 6mpg when he dumped the auto and put the NP435 back there. Again, it's an extreme example but that was the only thing he changed and it bumped him up 2mpg. If your goal is fuel efficiency and you have the option of either tranny I'd definitely choose the manual.
