Sponsored by: Auxito
Problems with ac and noise
Old Oct 18, 2005 | 08:59 PM
42o's Avatar
42o
03 V6 4.2 XLT 105,000 miles
When the truck is in drive and I turn on the AC/MAX AC options it starts making all kinds of noise (fast ticking) from under the hood. But when I put it on panel air or off it will go away. Putting the truck in park will make about 50% of the noise go away. It has been a gradual problem that used to be hardly noticable and now at drivethrus they cant hear what I'am saying. Any help would be great.
Old Oct 19, 2005 | 06:54 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 19, 2005 | 07:43 AM
l-m tech's Avatar
l-m tech
check your belt tensioner and belt.the belt might of stretched allowing the tensioner to hit the stop causing a noise.
Old Oct 19, 2005 | 05:52 PM
code_red's Avatar
code_red
might want to also check out your ac compressor clutch. It could be bad.Not sure if it would make a ticking noise. I had one go out on my last vehicle, but dont remember a ticking noise with it. One way to check if its fualty is to examine it(its on the front of the compressor sandwhiched between the pulley and the compressor). Mine was burnt up. you could see the burnt dust around it. when the ac was applied it would barely move as if it was hagning up
Old Oct 19, 2005 | 06:25 PM
CanadaGuy's Avatar
CanadaGuy
Clutches are quit common... but it could just be fast cycling from low refrigerant...
90turbo1
Jul 21, 2014 01:22 PM
MCDavis
2004 - 2008 F150
Jun 29, 2011 11:43 AM
sugar
3.8 & 4.2L V6
Nov 21, 2010 05:23 PM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Jul 17, 2009 01:35 PM
RTM
Jul 16, 2009 04:15 PM
