tuning a carter afb for e85
Old Oct 18, 2005 | 06:04 PM
clutch's Avatar
clutch
I recently decided to run my truck on e85 (85% ethanol) it is a 351w with 8.5:1 comp. and a 4bbl carter afb. I took the fill up the tank and see what happens approach to this conversion, and despite a few tense moments on the first trip I've about got it dialed in. I put larger jets in the secondaries and smaller metering rods in the primaries (they were a little rich to start with). I set the acceleration pump up and put in a larger fuel filter. It runs fine at higher rpms and accelerates as good as before. The only trouble i've been having is coming off idle. when I pull away from a stop it hesitates, sputters, and some times dies, as soon as I give it a little more throttle it evens out. What should I look at now.
Old Oct 18, 2005 | 07:52 PM
Ford_Six's Avatar
Ford_Six
Any rubber part in the system. All the hoses and the fuel pump need to be rated for alcohol/e85, as well as the seals in the carb.
It may need a larger accelerator pump shot or you may need to advance your timing a bit.
Old Oct 18, 2005 | 07:56 PM
1081's Avatar
1081
Accelerator pump in the carb?
Old Oct 19, 2005 | 06:55 PM
clutch's Avatar
clutch
I advanced the timing and that seemed to help. It now runs about as well as it did before. All of the rubber gas lines were replaced recently and I check them often. Milage is about the same, so unless cold weather gives me a lot of trouble I'll probably stick with it.
77truck460
Mar 17, 2015 11:07 AM
Paso1
Mar 9, 2015 12:22 PM
H311RA151N
Jan 31, 2015 05:25 PM
Hofeldt32
35
Jan 9, 2015 05:45 PM
kwanderi
Mar 20, 2005 04:09 AM
